Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
This is one of the rough aspects of selling DIY gear Soren (though I suspect you're very familiar with it). People tend to hold these small companies or individuals to the same standard as they would Amazon.
I guess the good part is - everyone's excited to get your board, and that's a good thing. :)
What about giving the US Office a break... They just got boards Monday, and the Tuesday workday haven't started there yet....
They got on it immediately. Order #100006030. Got shipment notification yesterday, and got UPS info this morning. Anticipated delivery on Friday. (This is to Wisconsin, via ground.):)
Yes,
try myself to find a good ssytem to avoid shorts on the close I2S legs (black connector)... despite the plugs I found this morning (have still to solder on it thin 50 ohms coax cables ! and put some thermal isolation tubes)
PSUD2 free soft as adviced by Randystuch member elswhere helps a lot to design a simple PS like a Pi with resistor e.g. ...
Well I have the pcb in front of me... outstanding viewing quality. Will take my time to avoid stupid fatal errors !
I am order 100006034 and have not received notification yet.
Since I didn't see the pre order list, one concern is that I didn't get on the list, maybe other people are worried about that too.
I expressed my interest in a post on this thread.
Randy
A high resolution image (well as much high reolution as the forum system allows) of Soekris's DAC :D
Hi!
Can someone explain to me simply and clearly how to be connected this DAC to a "USB to Spdif" converter ? it is a CM6631 converter.
(I have a Spdif out RCA connector in the converter and a coax cable to the DAC)
How to connect the volume pot? What kind of pot should I use???
Thanks in advance!
Disabled Account
Joined 2005
Randy
My order number was 100006028, and that shipped yesterday. Looks to me that they are working sequentially through order numbers.
UPS say that the board will be delivered tomorrow. It's currently on a stop-over in Hawaii. :)
At 1105 pacific time, I received shipment notification. It doesn't show up in the UPS system yet, but since they are in Cal I expect it by tomorrow or Thursday.
It lives !
I have the DAC working - playing music
Jriver-DiyinhkXMOS->SørenDAC->Amp->Speakers.
Couple of problems -
Volume using pot does not work, full (I think) volume when no pot connected.
Plop come click when changing for 44k to 384k.
Sounds very promising.
More testing tomorrow with a better amp and speaker collection.
Also have Amanero and other USB-I2S units to try.
Cheers, Dean.
The potmeter is not in the audio path, the uC have a A/D converter which read the value and send controls to the digital volume control in the FPGA.
But with 106 1db steps from -90 to +15 then it don't take much to change the volume level....
So, if I understand this correctly, with no pot connected (or with a pot connected and set to maximum) the DAC is playing at +15db?
