I'm just saying than the devices at each side of a tolinsk signal are not good and it's well known : often a spidf sounds better than a tolinsk.
It is not "well known". "Some people claim, based either on subjective, uncontrolled impressions or audiophile folklore that...." might be a more accurate phrase to use.
Yes surely more accurate.
And stay true, for the opposite :" tolinsk woulg give better result because just groundloop isolation".... without looking at the other problems it generates !
So is it false than "most" of the tolinsk connection are giving worst result than spidf ? Was it a plot from the spidf lovers VS the tolinsk ones for the last 3 years ?
Btw I was just answering to this partial "vue d'esprit" from TNT... so with all those folklores we will create TNT and I a grup .
Let's return please to the thread who was open by a non technician to help non-technicians... if you want of course !
Sure, if technical people are allowed to pitch in.
Are you collecting me into a "folklore" group?
As long as you don't dance around a "midsommarstång" (maypole) to accordion music...
Guys, I provide the wine !
Sure, if they stay more technical than philosophical !
Btw, here after a botle of wine, we scratch our heads because tolinsk sounds like spidf ANd to fest the good news, we open a bottle more !
As long as there is no herring involved...
And if you get drunk enough, you might even spell it "toslink"
Younger, a sweedisch girlfriend opened a ferment herring tin than they call the Surstoming . It is forbiden in the planes
oh man if you can eat that, you can eat all the french cheeses.
Ahaha I remember I looked at the botle of white wines and finally opened a frozen pepper vodka !
I might have lived in Amsterdam the last 17 years, but I am originally a swedish-speaking Finn.
Learned my electrical engineering and CS at the Helsinki University of Technology, my musicology at University of Helsinki, and spent much of my youth sailing the Baltic Sea and on the Åland Islands...
I am pretty sure it is banned by the Geneva Convention.
That's the spirit!Ahaha I remember I looked at the botle of white wines and finally opened a frozen pepper vodka !
Not this stuff?
Yes, as Soekris advised above, an isolation transformer is better than without, also with the isolated entries of the DAC.
I don't know but many listeners can listen to it when he has the choice on the same device between spidf and toslink
At least this is my understanding and experience.
We clearly lack clear testimonials about respective advantages between this two ways !
What you have experienced with your current DAC is not going to be indicative of how the Soekris DAC responds to COAX and TOSLINK.
FWIW S/PDIF is a data standard that defines two physical layers: RCA/BNC and TOSLINK. AES/EBU has an almost identical data format to S/PDIF, and uses a third physical layer using XLR connectors.
The conventional wisdom is that if a DAC has complete jitter rejection then there will be no difference between cable formats.
The FIFO method Søren has used is possibly the most effective way of eliminating jitter in the incoming data stream - to the point the jitter introduced by the clock, fpga and IC's on the DAC board should be the determinant of jitter levels at the output of the DAC.
As for TOSLINK being a bad protocol, I'll share my favourite online test data from a Stereophile review of a Musical Fidelity V-Link .
fig.1:The "eye pattern" of the S/PDIF data waveform, connected via 15' of plastic TosLink, was wide open and free from timing uncertainty at its start and end (fig.1), and the Audio Precision System SYS2722 calculated the jitter in this datastream to be a very low 395 picoseconds peak. This is not quite as low as the Halide S/PDIF Bridge, which measured 345ps peak, but was the same as the Stello U2. (All figures calculated with a 50Hz–100kHz measurement bandwidth.)
Pretty good performance for a protocol that is supposedly far worse than coax. Perhaps the V-Link has a superior TOSLINK implementation to your Squeezebox, but regardless it shows that TOSLINK is not inherently flawed.
Anyway, I suspect you'll find that the dam1021 will have little sensitivity to the different cable formats.
I asked for spidf mainly because I'm Squeezeboxed and twrak it with true 75 ohms plugs and wire. But this Squeezebox allows also toslink, but before a prove of concept if me, I will choose spidf first !
If you have a Squeezebox Touch you should definitely install the free EDO plugin and use the USB port as a digital output. Then get the excellent Amanero board and feed the Soekris dac with the I2S signal. I guarantee you won't look back.
The Amanero Combo board doesn't need drivers with Linux machines such as Squeezebox, and it's cheap too given it's marvellous performance.
It's a no brainer unless you use the USB port for music data. In that case I suggest you use the ethernet or wifi interface in stead.
any recommendations to I/V module?
Regards!
The R2R ladder produces a voltage at it's output. No I/V is needed.
...............................The FIFO method Søren has used is possibly the most effective way of eliminating jitter in the incoming data stream - to the point the jitter introduced by the clock, fpga and IC's on the DAC board should be the determinant of jitter levels at the output of the DAC.
I think Søren (soekris) mentioned that his FIFO scheme TRACKS the incoming clock to prevent FIFO overflow. http://www.diyaudio.com/forums/vend...-magnitude-24-bit-384-khz-57.html#post4135993 As per my humble understanding this is not the ultimate scheme in fighting jitter; Mark Levinson (name came because I used to have 360S) and many others have done that in 90'.
It seems Ian's (iancanada) approach is more comprehensive.
- Digital Line Level
- Soekris' DAC implementations
