Ultra-high performance, yet rather simple - hybrid and more!
Wow Evan, that is great news. Valery can say for sure but +-85 sounds a little high for two pair of outputs. Maybe if you stay with 8 ohm load. So glad you finally have it working. A great sounding system. I need to get mine installed in a case so I don't have to drag everything out every time I want to listen to it.
Congrats!!!!
I seem to have bad luck with some projects now matter how well I try to prepare. This one and the No GNFB input seem to be exceptionally buggy for me. The No GNFB input was actually my stupid mistakes causing the problems but this one still is plaguing me with DC offset issues and imbalance on one board. I'm running into DC offset issues with a set of CFA-CFP boards now too so I'm starting to become suspicious of this batch of op amps.
I'm using LF411. This was just a small batch of 10. I noticed quite a difference in offset voltage when I replaced one but it still wasn't at zero and seemed to drift around. I have more in stock now, hopefully from another manufacturing run. I found it really odd the first pair of CFA-CFP boards were 2-3mV (older stock) and the second pair drifted around -30mV. I haven't run into a bad batch of components like this before but anything is possible.
