You dislike the transformers or you dislike helping other people get them?Sorry I dislike
Have looked at the site and it is easy to register but, the Trafos of interest are on at least 9wks lead time.
Two points
1. 'W' equals Widerstände = Resistance, so KW equates to KOhm.
2. I had a problem finding what Trafo was SE and What was PP - I found this page from the manufacturers website :- see attachment.
Note they also do Power Trafos: - see second attachment
John
Two points
John
Hi Zoltán!I bought two transformers from, them. The small 5w el84 SE and a power transformer for a guitar tube amp project. I can buy it in Hungary from a reseller. Th quality is excellent.
Who is the reseller in Hungary?
greets:
Tyimo
Elektronkius alkatrészek és részegységek széles választéka. A TME kereskedelmi cég TME - Transfer Multisort Elektronik ajánlatában. MOLEX, FLUKE, RICHCO, SUNON, OMRON, TYCO, SCHRACK, KINGBRIGHT, KONTAKT CHEMIE, HIRSCHMANN, ANALOG DEVICES, AHi Zoltán!
greets:
Tyimo
give them a call 🙂
Just ordered two kits of trannies, for the Mullard 5-20 with 60-0-60v taps for a bias circuit, for £146.08 including VAT & UK delivery.
Each kit has one mains transformer, one choke and one pp output transformer exactly as the Mullard originals. I've chosen the "Drop-Thru" type.
Loads of other stuff on offer, at the moment.
UK Non JavaScript Price List
Unfortunately VVT are not competative into EU, they want a flat rate payment of 60Pounds Sterling whatever you order.
ie * SPECIAL OFFER * Magnetics Kit for Mullard 3:3 Mono costs 36.24Pounds Sterling to UK mainland but costs 96.24Pounds Sterling to EU
John
John
John
Hi John, do you know anyone in Dover with a boat? 😀
Also check out ges.cz: http://www.ges.cz/20power-suppliers...formators/low-frequency-transformers/XKD.html
They sell the TGL stuff but have some more transformers from other brands as well.
Hey, thanks for the reply, Osscar. What did you build?
I'm looking to make a SE guitar amp with an ECL82
i used TGL series : TGL 20/003 for 6c33c SE and TGL 20/002 for GU32 PP . I also used power transformers from indel - all of them you can see in pictures.Only INDEL technical information could have been more detailed (weight, size etc)
regards. oskars
regards. oskars
i think you can use TGL 5/001 or tgl5/002 depeneds on your speaker load. Indel OT have fixed output with single winding only.
- Tubes / Valves
- Found a CHEAP source of output transformers in Europe
