Found a CHEAP source of output transformers in Europe
Have looked at the site and it is easy to register but, the Trafos of interest are on at least 9wks lead time.
Two points
1. 'W' equals Widerstände = Resistance, so KW equates to KOhm.
2. I had a problem finding what Trafo was SE and What was PP - I found this page from the manufacturers website :- see attachment.
Note they also do Power Trafos: - see second attachment
John
Unfortunately VVT are not competative into EU, they want a flat rate payment of 60Pounds Sterling whatever you order.
ie * SPECIAL OFFER * Magnetics Kit for Mullard 3:3 Mono costs 36.24Pounds Sterling to UK mainland but costs 96.24Pounds Sterling to EU
John
i used TGL series : TGL 20/003 for 6c33c SE and TGL 20/002 for GU32 PP . I also used power transformers from indel - all of them you can see in pictures.Only INDEL technical information could have been more detailed (weight, size etc)
regards. oskars
