Upgraded Single Board PCM1794 NOS DDDAC
emyeuoi (x1)
PET-240 x2 + 2 set JFETS + 2 set Susumu
Myint67x1+1sets JFETS + 1set susumu
Juancho x2 + 2 sets JFETS + 2 sets Susumu
Sterlingmck x2 + 2 set JFETS + 2 set Susumu
BDL x1 + 1 set JFETS + 1 set Susumu
mbcoffman x1 + 1 set JFETS + 1 set Susumu
carlsor x1
naimster x2
kurand x1 + 1 set JFETS + 1 set Susumu
brettlb x1
SimonJ x1 + 1 set JFETS + 1 set Susumu
JanGr. (x1)
ed linssen x1 + 1set JFETS + 1 set Susumu (+ 2 sets of CCS parts )
tuyen x1 + 1 set JFETS + 1 set susumu
mr_whocares x1 + 1 set jfets + 1 set susumu
dwjames x1 + 1 set jfets + 1 set susumu
titus2002 x1 + 1 set jfets + 1 set susumu
PCB= 22
Parts= 16
@ titus2002
Look like you disappear from the list after your post... it is correct or maybe somebody overwrite your post?
Enrico
Hi Guys,
After an Acko S03 failure due my poor smd soldering skills plus the groupbuy is now in the hundred quantity, I decided not to proceed with this delicate mod concerns I could do more damage to my DDDAC which deems very satisfactory to my ears right now. 😉
I know I will kick myself later, but...., can't risk it with my skills!
So the order as it stands
ahh that's a shame. Don't be disheartened! The S03 is very fiddly to put together (I had to re-do mine a number of times because of silly soldering faults) but these CCS boards, although they use SMD, will be much easier than the S03. The 2SK208-O only have 3 legs and they're not close to each other
and the resistors are 1206 size, which is a lot larger than those in the S03.
Once you have the CCS boards built, it's simple to test them, then adding them to your dac boards (although means taking your stack apart again) is a very simple soldering job with no fiddly bits.
Of course it's your choice, but don't let the very fiddly S03 put you off this, because it's quite different.
Hope that helps one way or another 🙂
James
emyeuoi (x1)
Myint67x 3, + 3set JFEct + 3set SuSumu(request for pre solder if available)
carlsor x1
naimster x2
brettlb x1
JanGr. x1 + 1 set JFETS + 1 set Susumu
Sovereign x2 + 2 sets JFETS + 2 sets Susumu
titus2002 x1 + 1 set JFETs + 1 set Susumu
PCB= 26
Parts= 21
emyeuoi (x1)
carlsor x1
naimster x2
brettlb x1
rickmcinnis x1 + 1 set JFETS + 1 set Sumumu
PCB= 27
Parts= 22
Just hope I can make it work.
Hope I did this right.
Thanks to you and carlsor for this.
Hope not too late:
emyeuoi (CCS x 2)
carlsor (CCS x 4)
juancho (CCS x 4)+parts
crazyfrog (CCS x2)
mk57 (CCS x 8) + parts
SimonJ (CCS x 2) + parts
PET-240 CCS x 4 + parts
sterlingmck (CCS x 4) + parts
zz1969 (CCS x 8) + parts
kurand (CCS x 4) + parts
mbcoffman (CCS x 2) + parts
Myint67 (CSSx16) + Parts
tuyen (CCS x 8) + parts
Brumjam (CCS x 4) + parts
mr_whocares (CCS x 2) + parts
tods (CCS x 8) + parts
IanS1 (CCS x 4) + Parts
dwjames (CCS x 2) + parts
titus2002 (CCS x 8) + parts
Chanh CCS x 24 + parts
BDL (CCS x 2) + parts
Sovereign1 (CCSx40 +Parts
rickmcinnis (CCS x 2) + parts
Total CCS= 127
Parts = 119
Thanks again,
emyeuoi (CCS x 2)
carlsor (CCS x 4)
crazyfrog (CCS x2)
Sovereign1 (CCSx4) +Parts
Total CCS= 104
Parts = 96
Hope not too late:
emyeuoi (CCS x 2)
carlsor (CCS x 4)
crazyfrog (CCS x2)
Superberg (CCSx20) + Parts
Total CCS= 146
Parts = 138
It is not so difficult... the parts are not so tight and the most complicated ones are the BFs. With a little patience and a magnifier I am sure you will do it 🙂
Enrico
PS: I will resend your post with the total figures updated
Thanks, after I posted I could see it was wrong but did not know what to do.
I want the buffer board and parts, too.
Take care and happy new year!
No problem Rick and the buffer board and part are ok.
You are not the only one... Superberg did the same and I will resend the CCS list corrected 🙂
Please guys, update the latest list in the thread.
Thanks to ALL of you for the unexpected performance of the GB. Tomorrow I will close the GB and by Monday/Tuesday I will inform everybody here about the cost of the boards and the shipping.
With this figures I can estimate that the CCS board will be 2,5 USD and the Buffer board will be 12 USD but let me ask a confirmation from the manufacturer when the GB is closed.
Best Regards,
Enrico
emyeuoi (CCS x 2)
carlsor (CCS x 4)
crazyfrog (CCS x2)
Superberg (CCS x 20) + parts
Total CCS= 124
Parts = 116
It certainly would not offend me if you put some extra in the price for your troubles. And while we are at it there should be consideration for carlsor.
The prices quoted are extremely reasonable. Almost too reasonable.
I am sure there will be much more time spent on this than you expect and I think we should compensate you for that quantity always in limited supply.
I doubt there are any of us who would feel otherwise.
Rick,
Your post make me proud and happy of my time spent in this GB that BTW is my first GB. THANKS!!!
My intention opening the GB is just to help ALL of you guys to improve, if possible, the fantastic DDDAC. This for me is the true spirit of the DIYers. Isn't?
And know that you all will have my own small part in your DDDAC makes me really proud 🙂
Thanks again,
Enrico
Late into the CCS order...hope I am not too late. 🙂
emyeuoi (CCS x 2)
carlsor (CCS x 4)
crazyfrog (CCS x2)
Naimster(CCS x 16) + parts
Total CCS= 140
Parts = 132
1/2 Clock Delay - Another GB?
Hi All,
One of the modifications explained by carlsor is the 1/2 clock delay circuit that is in my opinion a must to have if you own the red board.
Here is the design of the PCB. If somebody is interested on it I can run another GB... the board is small (30 mm x 15 mm) and the minimum quantity to place the order is 20 board.
I install the 1/2 clock delay in my red board and I can confirm that is a HUGE step ahead.
I attached few pictures of my red board where you can see how is integrated the 1/2 clock delay (it is not my PCB but the result is the same). You can easily put the board in the middle of the red board, mark the holes for the cables and make the small holes that you need to connect with the red board.
If you are afraid about the SMD I can also send the board with the 2 VHC already soldered.
So, as usual, please add your name below 🙂
emyeuoi (CLOCK x 1)
Hi All,
Excellent work!
I made my own and it was very fiddly, but this looks neat and tidy and much simpler. I am jealous that people will have it so easy now! 🙂
I can highly recommend this mod for anyone with the older red mainboard. The improvement in the clarity of sound was well worth it to create my own from scratch, but now it's all done for you it's a no brainer.
Buffer GB
I just increase my pre-order by a second set of the buffer 🙂
thanks!
emyeuoi (x1)
carlsor x1
naimster x2
brettlb x1
mr_whocares x2 + 2 set jfets + 2 set susumu
PCB= 28
Parts= 23
