emyeuoi (CCS x 2)
carlsor (CCS x 4)
juancho (CCS x 4)
crazyfrog (CCS x2)
mk57 (CCS x 8) + parts
SimonJ (CCS x 2) + parts
PET-240 CCS x 4 + parts
sterlingmck (CCS x 4) + parts
zz1969 (CCS x 8) + parts
kurand (CCS x 4) + parts
mbcoffman (CCS x 2) + parts
Myint67 (CSSx2)+ parts
tuyen (CCS x 8) + parts
Brumjam (CCS x 4) + parts
Total CCS= 58
Parts = 46
carlsor (CCS x 4)
juancho (CCS x 4)
crazyfrog (CCS x2)
Total CCS= 58
Parts = 46
emyeuoi (CCS x 2)
carlsor (CCS x 4)
juancho (CCS x 4)
crazyfrog (CCS x2)
mr_whocares (CCS x 2) + parts
Total CCS= 60
Parts = 48
carlsor (CCS x 4)
juancho (CCS x 4)
crazyfrog (CCS x2)
Total CCS= 60
Parts = 48
emyeuoi (x1)
PET-240 x2 + 2 set JFETS + 2 set Susumu
Myint67x1+1sets JFETS + 1set susumu
Juancho x2 + 2 sets JFETS + 2 sets Susumu
Sterlingmck x2 + 2 set JFETS + 2 set Susumu
BDL x1 + 1 set JFETS + 1 set Susumu
mbcoffman x1 + 1 set JFETS + 1 set Susumu
carlsor x1
naimster x2
kurand x1 + 1 set JFETS + 1 set Susumu
brettlb x1
SimonJ x1 + 1 set JFETS + 1 set Susumu
JanGr. (x1)
ed linssen x1 + 1set JFETS + 1 set Susumu
tuyen x1 + 1 set JFETS + 1 set susumu
mr_whocares x1 + 1 set jfets + 1 set susumu
PCB= 20
Parts= 14
carlsor x1
naimster x2
brettlb x1
JanGr. (x1)
PCB= 20
Parts= 14
emyeuoi (CCS x 2)
carlsor (CCS x 4)
juancho (CCS x 4)
crazyfrog (CCS x2)
tods (CCS x 8) + parts
Total CCS= 68
Parts = 56
carlsor (CCS x 4)
juancho (CCS x 4)
crazyfrog (CCS x2)
Total CCS= 68
Parts = 56
emyeuoi (CCS x 2)
carlsor (CCS x 4)
juancho (CCS x 4)
crazyfrog (CCS x2)
IanS1 (CCS x 4) + Parts
Total CCS= 72
Parts = 60
carlsor (CCS x 4)
juancho (CCS x 4)
crazyfrog (CCS x2)
Total CCS= 72
Parts = 60
emyeuoi (CCS x 2)
carlsor (CCS x 4)
juancho (CCS x 4)
crazyfrog (CCS x2)
dwjames (CCS x 2) + parts
Total CCS= 74
Parts = 62
carlsor (CCS x 4)
juancho (CCS x 4)
crazyfrog (CCS x2)
Total CCS= 74
Parts = 62
emyeuoi (x1)
carlsor x1
naimster x2
brettlb x1
JanGr. (x1)
dwjames x1 + 1 set jfets + 1 set susumu
PCB= 21
Parts= 15
Also, just to add, if people don't have a power supply in mind yet for their buffers, I think one of these would do the job well for low hassle and low cost
4.17uV Ultralow noise DAC power supply regulator +-12/15V 1A - DIYINHK
carlsor x1
naimster x2
brettlb x1
JanGr. (x1)
PCB= 21
Parts= 15
emyeuoi (x1)
indeed, a nice power supply. shall we put that also to the GB in order to complete the kit? I would like to have one
Dear All,
carlsor kindly highlight to me that the 2SK208, as per datasheet, need to be flipped.
Thanks carlsor to catch it
Attached the new layout of the CCS circuit.
Tomorrow I will close the GB and in few days I will send you a PM with the final amount including handling/shipping. Please reply to the PM with your paypal account and the exact shipping address.
Thanks and Happy New Years to all of you and your families.
Enrico
Hi Enrico,
If you give this GB a few more days, I think you will easily pass the 100 piece price point?
Ed
pdb Answer Re Volume Pot
No. The buffer outputs are about 2.8V above DAC signal ground and are designed to drive a Transformer or capacitors. The audio signal to a volume control pot is usually at signal ground with no music playing. The Transformer does this conversion.
Question: Could the buffer with psu's and a volume pot be used as a simple preamp with no gain? If yes, what would be the prefered impedance for the pot? Thanks. Per
__________________
pdb
Thanks carlsor for your quick answer. Silly question: If I added in a pair of cinemags AND a volume pot - or a TVC w the buffer - would that make a preamp?No. The buffer outputs are about 2.8V above DAC signal ground and are designed to drive a Transformer or capacitors. The audio signal to a volume control pot is usually at signal ground with no music playing. The Transformer does this conversion.
emyeuoi (x1)
carlsor x1
naimster x2
brettlb x1
JanGr. (x1)
ed linssen x1 + 1set JFETS + 1 set Susumu (+ 2 sets of CCS parts )
PCB= 21
Parts= 15
carlsor x1
naimster x2
brettlb x1
JanGr. (x1)
PCB= 21
Parts= 15
I'm confused... There's a lot of guys running direct from the mainboard pos and neg outputs without caps or transformers with good results, how does this differ? The +2.7v dc offset of the pos and the -2.7v of the neg cancel out to give close to a dc offset of zero.No. The buffer outputs are about 2.8V above DAC signal ground and are designed to drive a Transformer or capacitors. The audio signal to a volume control pot is usually at signal ground with no music playing. The Transformer does this conversion.
The buffer uses the pos and neg as inputs and the dc offset that comes out of the buffer is tweakable to be zero via the trimpot.
Is it just a safety thing, that if something goes wrong you could feed a 2.7v dc offset into your amp that's the issue?
Not having a go, just curious
James
Direct Feed
All four of the differential outputs from the DAC outputs are about +2.7V above DAC signal ground into Rload resistors. The Pos and Neg outputs of each side are both +2.7V. There is no such thing as a +2.7V pos cancelling a -2.7V neg. The differential between these two is usually less than 2.0mv. With the buffer this difference can be adjusted close to 0.0mv, but is still about 2.8v above DAC signal ground. It is a little higher than 2.7V because the Buffer JFETS are operating at 70-80% of Idss.
Doede's DAC and the buffer are designed to feed output transformers or output capacitors. Direct feed to preamps or amps may or may not cause problems depending on the equipment and how they are connected. Differential connections have the best chance of success. It depends on how the down stream equipment deals with the +2.7V output signals. My guess is that the DAC ground is not even connected. No one explains exactly how they directly connect the DAC to equipment. I wish these were explained in the forum. A TVC volume control might be able to function like an output transformer as long as it is not putting 2.7V through it to ground.
I recommend that the buffer NOT be used to directly feed equipment. Do this at your risk. If a Buffer JFET blows up then the output becomes a 12-15ma current sink limited by the constant voltage transistor operating at about -2.75V. I can always supply more JFETS. If someone insists of using the Buffer to directly feed something then put at least 470 ohms in series between the buffer outputs and the direct feed as a test that might not blow up anything. Usually an input transistor or input tube is an easier load to drive than an output transformer so a buffer wouldn't be much benefit.
Thanks carlsor - even though this answer was not directed at me (I think) My question was IF the buffer could be transferred into a (safe) preamp - with trafos, caps or other means. I have always felt that no (or very little) DC on the input of DC coupled amp(setup) has to be no or little DC under ANY CIRCUMSTANCES. Sorry for any off topic confusion. Back to the group buy listings...All four of the differential outputs from the DAC outputs are about +2.7V above DAC signal ground into Rload resistors.....
Hi Enrico,
Ed
No problem. I will keep the GB open up to next friday.
Regards,
Enrico
Sorry yes, my bad... the DC offsets for pos and neg are both +2.7v or thereabouts, So the DC offset between pos and neg is minimal. Usually only a couple of mv, depending on how accurately matched the I/V resistors are I believe.All four of the differential outputs from the DAC outputs are about +2.7V above DAC signal ground into Rload resistors.
The audio signals on pos and neg are the same, but opposite phased.
So what some people have been doing is ignoring the common (dac gnd), and just using pos and neg as a single ended output with almost no DC offset and not using any caps or transformers on this output. Neg becomes RCA gnd. Obviously it's not the recommended route (and I wouldn't be happy doing it on an amp without some form of coupling capacitors or transformers before the power stage) but some have found this works well for them.
emyeuoi (x1)
carlsor x1
naimster x2
brettlb x1
JanGr. (x1)
titus2002 x1 + 1 set jfets + 1 set susumu
PCB= 22
Parts= 16
carlsor x1
naimster x2
brettlb x1
JanGr. (x1)
PCB= 22
Parts= 16
- Digital Line Level
- Upgraded Single Board PCM1794 NOS DDDAC
