900W H-class PA Amp with Limiter
hi all my layout of apex h with transitor drive please check and add comments or compliments
  • gtG apex h 900 schematic.pdf
apex h900 in case and showing his power
east and west
apex h900 topology is best
leave the rest
bass response is good pounding the chest
if don't believe make yourself then test
its never behind from crest
apex sr200 is my next
hi apex sir,i don't want to hear bass under 50hz because i don't like it.is there any circuit?thanks.
There is low cut filter on BA1200 XLR input circuit.
Just adjust the component values of the Passive RC input filter.
But have you investigated whether it is your speakers that create the "unpleasant" bass?
Very many commercial speakers are designed to give a "more bass effect" than their small size is capable of.
This "effect" is achieved by setting the speaker Q to a value higher then 0.7, sometimes higher the Q>=1
This gives a very "unreal" sound than many listeners do not like.
It would be worth experimenting to try to find out what it is that you find "unpleasant".
working stepdrive
yes QQ12e5k1 made this and i build this to prove and share th
this is my first post in this forum. i've been reading topics here for sometime and this captured my interest. is this stepdrive circuit working, no issues of rail sticking or any problems encountered. i am planning to revive my mobile sounds and i'm planning to use this amp for low frequency application. looking forward to any replies on my querry. thanks in advance.
