100W Ultimate Fidelity Amplifier
Thanks,
It is playing fine now with the zobel attached. I listened to it for a while. Sounds very good as expected. The gain is a little lower than some of the other Apex amps. When I find my camera I will show some square and sine waves.
Blessings. Terry
Super.
I'm just a hobbyist. If an amplifier is not working as expected, I'm always in trouble 🙂.
But get it running is exciting.
regards.
A23 test 15kHz 1V/div 8r with 470nF in paralell.
A33
Hi, I started to design a layout for the A33. This is the very first draft for the input stage. I do not know if it's a good idea to share the PCBs in two parts. This gives a better handling during the test. If everything works out, we can make a complete PCB. Recommendations very welcome! Maybe someone can look at the design, I have to double check everything.
Regards Olaf
