Schematic wanted for VTL Preamp "Maximal"
I am looking for images of the PCB, but the bottom view, so as the PCB layout.
Maybe this helps to avoid removing the complete PCB for troubleshooting, which is extremely time-consuming.
Thank you very much for upload.
in the attachment (first image) the bottom view.
In the second schematic of post #3 there are no values noted for the RIAA equalizing network. Who know the values ?
Any experiences concerning replace the present couple capacitors (VTL labeled) by this one from Jantzen Audio ?
http://www.jantzen-audio.com/superior-z-cap/
https://quint-store.com/media/files...dd066ec56d5db/Jantzen Superior-Z-Cap-List.pdf
https://quint-store.com/media/files_public/75238661f2268347a6bdd066ec56d5db/Jantzen Superior-Z-Cap-List.pdf
In the attachment my own created schematic of the device in question.
Main difference which I note to VTL's genuine circuit diagram are between
1) - the values of caps in the signal pad labeled with VTL (1K/22K = 1nF/22nF vs. 0,1µF and 0,22µF in the second schematic of post 3) and
2) - the not present cartridge input load capacitor in parallel to the 47K5 resistor (150pF in the second schematic of post 3)
the marked values on caps in the signal pad (1K/22K - labeled with VTL) haven't to do with those in real life. = 100 nF
Follow values I note by measuring with multi meter:
1K = 100 nF (0,1µF)
22K = 220nF (0,22µF)
P.S.: I want to know, what kind of bypass foil capacitor is a good choice to solder in parallel to the 220µF (between cathode and GND) - taking into account the limited space ?
Either one decide on an MKS/MKT version with a higher value or with the same size for a lower value - but then with the higher-quality - i.e. MKP/FKP version (due the low voltage condition on that point a 63V version is enough).
Any experiences ?
some images from various devices of this model
  • VTL Maximal short form test Stereophile-1989-09-IDX-169.pdf
  • VTL Maximal short review Stereophile-1990-01-IDX-199.pdf
more images from various devices of this model
According internal images, the model "MAXLINE" is identical with the model "MAXIMAL" but without the RIAA-stage
