S03 Bare Boards
Acko X10 (Paid-On Order)
Greg Stewart 2 (Paid-On Order)
Emyeuoi X2 (Paid-On Order)
flowerpot x 4 (Paid-On Order)
JimS x 2 (Paid-On Order)
RollE2k x 1 (Paid-On Order)
carlsor X 2 (Paid-On Order)
tuyen X 1 (Paid-On Order)
lemon X 1 (Paid-On Order)
Stijn001 x1 (Paid-On Order)
Adamantine X 3 (Paid-On Order)
hochopeper x 1
Supersurfer x1
dsdjoy x 1
curryking x 3 (Paid-On Order)
kannan_s x 2 (Paid-On Order)
potstip x 1
taisho_daniel x 1
duster1 x 1
__________________________________________________
BBB-UFL board
Acko x 1
tubesguy x 1 (with UFL)
nautibuoy x 1 (with ufl)
bk856er x 1
emyeuoi x 2
deanoUK X 2
Chanh X1 (with UFL mounted)
Greg Stewart x 2
Stijn001 2x (with UFL mounted)
Palmito x2
Myint67 x2 (with UFL mounted)
potstip x 1 (with UFL mounted)
TheShaman x 1 (with UFL mounted)
taisho_daniel x 1
hochopeper x 1
Supersurfer x1
dsdjoy x 1
potstip x 1
taisho_daniel x 1
duster1 x 1
BBB-UFL board
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
S03 Bare Boards
In production. ETA stock 21st Nov 2014
hochopeper x 1 (Paid-On Order)
Supersurfer x1
dsdjoy x 1
potstip x 1
taisho_daniel x 1 (Paid-On Order)
duster1 x 1
BBB-UFL board
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
Supersurfer x1
dsdjoy x 1
potstip x 1
duster1 x 1
BBB-UFL board
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
S03 Bare Boards
Supersurfer x1
dsdjoy x 1
potstip x 1
duster1 x 1 (Paid-On Order)
BBB-UFL board
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
Supersurfer x1
dsdjoy x 1
potstip x 1
BBB-UFL board
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
I posted this in the amanero thread also - but i also do it here....
So - which Amanero firmware is best to run when using Acko isolator/reclocker nowadays? I think the 1093 didn't work good - but what about 1082_USB10e, 1082A or 1084? Also is CPLD_for_1080 or CPLD_1080_XC12 the one to run?
For full sync re-clocking, you should use Slave_for_1080 and firmware_1080 as per Amanero's advice with the S03 setup. Then from Configbits tab set:
Prescaler: MCLK/1
Word length: 32
Stream format: I2S
Slave Mode (MCLK Input): select
Pin1: 22.579MHz
Pin11: 24.576MHz
S03 Bare Boards
Supersurfer x1
dsdjoy x 1
potstip x 1
IanS1 x 2
BBB-UFL board
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
IanS1 x 2 (with ufl mounted)
hochopeper x 1
Supersurfer x1
dsdjoy x 1
potstip x 2
BBB-UFL board
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
iancortez x 1 (with UFL mounted)
hochopeper x 1
Supersurfer x1
dsdjoy x 1
potstip x 2
BBB-UFL board
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
S03 Bare Boards
CLOSED
Supersurfer x1
dsdjoy x 1
potstip x 1
IanS1 X2 (Paid-On Order)
CLOSED
BBB-UFL board
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
CLOSED
Supersurfer x1
dsdjoy x 1
potstip x 1
CLOSED
BBB-UFL board
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
PET-240 × 2 (with ufl)S03 Bare Boards
CLOSED
Supersurfer x1
dsdjoy x 1
potstip x 1
CLOSED
BBB-UFL board
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
Apologies for the messed up list, mobile access only and it kept deleting half the bleeding list!
Thanks Acko,
Chuz,
Drew.
Thanks Acko,
Chuz,
Drew.
S03 Bare Boards
CLOSED
Acko X20 (Paid-On Order)
Supersurfer x1
dsdjoy x 1
potstip x 1 (Paid-On Order)
CLOSED
BBB-UFL board
CLOSED
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
IanS1 X2
CLOSED
Progress:
Manufacture Instruction: Completed 2014-11-10 19:25:14
Board Cutting: Completed 2014-11-10 20:11:12
Drill: Completed 2014-11-11 2:35:29
Plated Through Hole: Completed 2014-11-11 13:01:06
Circuit Completed: 2014-11-12 1:34:32
Etching:
AOI:
Solder Mask:
Silkscreen:
Surface Treatment:
Routing:
Testing:
Assembly:
Package:
Delivery Ready:
CLOSED
Supersurfer x1
dsdjoy x 1
CLOSED
BBB-UFL board
CLOSED
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
IanS1 X2
CLOSED
Progress:
Etching:
AOI:
Solder Mask:
Silkscreen:
Surface Treatment:
Routing:
Testing:
Assembly:
Package:
Delivery Ready:
SuperCape Update
UPS:
1. UPS kicks in when external power is removed.
On-board PWR_MON will continue to power the BBB (~1hr) or options to safely shutdown BBB immediately.
Same shutdown action if battery level goes below operational level
2. Automatic boot from SDCARD or internal Flash. No boot button press required.
The above features will practically result in a reliable 'fail-safe' system that can be tucked away
Yes, this is in the works. The concept (as posted earlier) had lain fallow for while to get more ideas but I have now got all the bits and pieces to roll out a board. Yes, it will match the BoticOS interface for I2S/DSD. No plans for a GB as yet. More of build and supply for those who are interested.
UPS:
UPS:
Nice one, Acko! Please advise the availability and cost?
Chanh
Sweet!
How about circuits for at least one added sdata line, if not more? I understand the Botic driver supports 8 channels, and I need 4. Only populate the board as needed.
...with great interest,
Frank
@Acko, where can we find a BOM for the S03 bare board?
Thanks!
Please wait for a while. I am updating the support information and will be ready early next week.
S03 Bare Boards
CLOSED
Supersurfer x1 (Paid-On Order)
dsdjoy x 1 (Paid-On Order)
CLOSED
BBB-UFL board
CLOSED
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
IanS1 X2
CLOSED
Progress:
Circuit: Completed 2014-11-12 1:34:32
Etching: Completed 2014-11-12 14:38:48
AOI: Completed 2014-11-12 14:39:02
Solder Mask: Completed 2014-11-12 14:39:18
Silkscreen: Completed 2014-11-12 14:39:34
Surface Treatment: Completed 2014-11-12 18:20:47
Routing: Completed 2014-11-12 19:39:09
Testing: Completed 2014-11-13 4:54:13
Assembly:
Package:
Delivery Ready:
CLOSED
CLOSED
BBB-UFL board
CLOSED
Acko x 1
bk856er x 1
emyeuoi x 2
deanoUK X 2
Greg Stewart x 2
Palmito x2
taisho_daniel x 1
IanS1 X2
CLOSED
Progress:
Assembly:
Package:
Delivery Ready:
- Group Buys
- Amanero Isolator/Reclocker GB
