I believe you would have similar results if you used ZYX TB/SB mass weights instead of shakti.From your photo the ZYX has no mass weights,so,its weight is 5gr and possibly arm/cartridge resonance is on the high side without them considerin the zyx's low compliance.The shakti acted as a mass weight imo.
I use a zyx/sb on my turntable and surely the sb weight was necessary to have a resonance at around 9-10 hz.
I don’t completely reject your explanation. Your explanation is an hypothesis. EMI reduction is an hypothesis, too. Both don’t have scientific evidences to support. Which one we should believe? I lean towards EMI reduction in the case of shakti.
In my opinion, arm/cartridge resonance theory can be very well applied to different cases. For example, the tightness of cartridge screws has an impact on noise level and sonic characteristics. I also made some carbon fiber washers for cartridge. Please see the photo. These washers also have impacts on arm and cartridge resonance. I can hear reduction of background noise.
One is based on science, the other is based on babble used to defraud the gullible.
Arm/cartridge resonance, I mean the resonant frequency caused by total effective mass of tonearm/cartridge/screws and cartridge compliance.Not any stractural resonances of tonearm or cartridge body etc... that can be reduced by different means.
Do a search for longhorn cartridge mod. There are other discussions besides this one, though I'm posting it for the link to the Audio Basics Longhorn article from 1982:
" Longhorn" Modification revisited
Here are some pictures of my longhorn mod :
http://www.diyaudio.com/forums/analogue-source/253888-my-longhorn-mod.html?highlight=longhorn
