900W H-class PA Amp with Limiter
is this correct sir?
psu is 120-60-0-60-120 dc
i add h200 step driver for h900,
any change or replacement for this schema?
hello sir mile,
greetings. i would like to use this h-step on the hv23 mosfet amp. you said that for 4 pair outputs, you use 4 pair h step mosfet.
can i use 2 pairs irf540 for h step instead?
can i use h900 psu for the amp?
what va rating for transformer to use?
also any changes in terms of wattage to make to the h step resistors, capacitors and diodes.
hello sir mile,
This h-step can't be use on nv23.
psu 112-56-0-56-112 v dc
