hi apex sir,
can u check post 721.
Your amp is OK, and you can use +/-95V DC rail with 4R loads in real life.
which ba1000 version better? with bd139 bias or bd681 ?
BD139, and this is 12 LED level meter version.
Hi sir mie
please share your PCB and SHEMATIC for this vu meter
thank you
is it 5v dc supply for vu meter?
Yes +5V , - connect to amp gnd and IN to amp out... pcb size 100x35mm.
i am looking for 2years for vu meter with lm 339 or lm 324.i found only with lm 3915 and lm 3914.i saw vu meter with lm 339 in many professional mixer and they use ne 5532 op amp.thanks to apex sir.
There is my old stereo dot VU with LM324.
3mm or 5mm LED??
3mm or 5mm LED??
5x5mm or 2,5x5mm LEDs, any can be use.
Hi
can you share shematic too?
Ok, I tried to make in 5mm LED but it's very congested I can't make my PCB size in 100 X 30mm.
anyway i'll try with this one for now, Thanks.
Nice work, 120x35mm is ok, my is 100x35mm but leds are too close.
Noted, Thanks....
IN is connected to amp OUT? What signal strength is measured?
- 1000W Simple PA Amplifier
