Amanero Isolator/Reclocker GB
Pleasure! precious cargo 🙂
... back to business, your current setup has set a very high bar and my minimum expectation is for the SO3 to better it given that it has isolation and re-clocking that eliminates jitter with reference to a low phase noise clock. Also, as the clocks are 45.xx/49.xxMHz types you should only use it with BBB or similar in full synchronous re-clocking.
S03 bare boards. No components mounted or supplied
Min order 50pcs
Price each $25
If interested please add to this list
Acko X10
Greg Stewart 2
Emyeuoi X2
flowerpot x 3
if we could not get minimum order any possibility to have a lower order qty but at a slightly higher price ?
Min order 50pcs
Price each $25
Acko X10
Greg Stewart 2
Emyeuoi X2
flowerpot x 3
If the list stagnates after a while ~30days I will advise other options.
I will not keep you all waiting too long🙂
Jitter elimination - S03 Synchronous Re-clocking
Re: timing diagram
The delay parameter 'd' can be considered as a snapshot of jitter and see how the output remains locked to the reference clock
Min order 50pcs
Price each $25
Acko X10
Greg Stewart 2
Emyeuoi X2
flowerpot x 3
JimS x 1
Report Post
EDEL NMR Pricing
I've queried availability and pricing via the website. I will report back when I know more.
Ray
Hopefully Acko won't mind me posting this info on his thread; if it looks as though there is mileage in it we can move it elsewhere.
OK, I got the information through about the Edel Network Media Renderer boards;
Network Audio Renderer | ABC PCB
The cost of a single board works out at about $485 (£302, 383Euros) before taxes and shipping. At 10 boards the unit price falls to about $460 (again before taxes and shipping) and there are further price breaks at 25 boards and above.
So the boards are quite expensive and you would need to buy a lot to get a significant reduction in the unit price. Does that sound like a viable group buy - I'm not convinced and it would seem to be easier to just buy a single board if you want one - what do you chaps think?
The information I received gives the prices in Swiss Francs and the numbers above are based on today's exchange rate.
Ray
