6V6 line preamp
Hi Salas,
I'll just stick with the cap.coupling then. But if cost is not an issue and a lower output impedance is.needed what output transformer spec is ideal?ty
Something with 150-200H @ 20mA & 600 Ohm output I guess. As for ratio keep in mind that you start with 20dB max available when choke loaded. 15.5dB for resistive load. THD gets seriously better with inductive load as the signal swing increases.
Hi Salas,
Im gonna have heyboer wind a pair of Opts using the specs you gave. What primary impedance should be needed? Im gonna need half the gain, so what ratio.will be ideal?
Ty
Yes. But no further benefit in reducing the output impedance. With 1:2.5 its 12dB. When 6-9dB gain with a line source should be covering a very wide range of amps and the step down ratio cuts on microphonics and noise too. For 9dB it would be 1:3.5
Hi Salas,
Thanks again... ill see if heyboer can make those opts. My friend heard my 6v6 pre and loves it. His amps is a 3 stage pp 6l6 design which already has enough gain that a normal 2v source can drive it to full power.
He wants to build a 6v6 too and I told him to build the cathode follower version but since an output transformer can be used to step down the output of the common cathode design, what step down ratio is ideal so the common cathode 6v6 will have a 2v output?
