Describe the circuits for your digital inputs.
sir andrew this is the digital inputs i buy it ready made from electronics shop here in dubai..
Also available on eBay here Digital red LED 12v Bluetooth mp3 decoder board FM Radio usb sd AUX+Remote F/CAR | eBay
here is also my other toy....
And here is the latest""" like a bomb..
Small but very good sounding amp. i build this amp. many times...
Some interesting views, thanks for these.
thanks you bentanake...regards..
More 10watts pcb..
More 10watts pcb..
My LM386 small amp.
My LM386 small amp.
tda2616
thank you so much Sir jmf ahey...god bless sirCool !!!
Very nice ideas
Can you give us more detalis about building amplifier case(first post, with mp3 player module)?
yes of course..why not..here it is...
i use 8mm mdf fly wood for casing..size is L-27.5 cm , W-18cm and H-11cm and i cover it with black cloth.. i use autocad for making front and rear panel shown in the picture..and by tomorrow i give the details on how to hook up the digital mp3 player /fm radio to my main amp. just for fun but very good sounding and also powerful amp.
connections..
i use ordinary GI SHEET Gouge 20 and then i make a front and rear panel design from autocad i send it to calligraphy shop to print in to glossy sticker with laminated clear plastic on it..I have that same module connected to TPA3116 amplifier, now I am looking for case for both amplifier, mp3 player and power supply. What kind of cloth is it, some kind of carpet? Are front panels made from aluminium or?
the cover is similar like a carpet i found it at the textile shop , hopefully there is also in your place the thickness of the cloth is 3mm.
More 10wX 10w power amp..i use ordinary GI SHEET Gouge 20 and then i make a front and rear panel design from autocad i send it to calligraphy shop to print in to glossy sticker with laminated clear plastic on it..
- Chip Amps
- 10watts power amp.
