900W H-class PA Amp with Limiter
apex h900 v2
some progress.one channel work in ab class on +-55 because he is waiting for ir 2117.sound quality is best as i know because it has label APEX on it.
hi, today i check my h900 output voltage.excellent result.input 50hz sine wave output more than 70v.my clip led glown at 62v.thanks to sir mile.i want to tell more about sir mile ,everybody also know it already.his response is quick than anyone and more friendly attitude.
To apex sir
one difficult question how to check short circuit protection fuction through amplifier? before make my amp my question about limiter is limiter should work on 65v.now i made it check it , starts at 62 v.i want same that.in earlier post you tell us that it will clip before 15v of hv rail.if hv is 110 then it clip on 95v.is this other format vpf or rms or acv?.sir please explain i want to know.
hi ,thanks apex sir i knew that you cann't be wrong.there is some misunderstanding.anyhow i made my h 900 v2 without any probelm even amp start at my first attempt.i want to thanks to apex sir,aman khalsa,sandeep,wattaniya.perhaps i did a mistake that i make my toroidal near 2200 va.this is too much for h900 stereo because i check with my meters amp never take even 4ampere at good load.thanks again.
hello sir Mile is there a way to connect the circled area to two seperate channels since the original design is for one channel? and if possible edit the schematic to show stereo connection.
Do not connect the mosfet yet. Measure the voltage at the pcb point where the gate is connected. Slowly adjust the volume until you get a voltage reading. Compare it to the datasheet of mosfet on the point that when it will start to conduct.
hi dear sir, you cann't get my point.when gate is open that time this happen.it mean all mosfet will do the same behave.after installing ic its ok.once again when mosfet gates in open position its behave like on switch.this will happen all the time when mosfet working in same circuit like this amp.
