11 year cycle
Well those arguments never go away, same responses as well.
However here's a way of easily assessing any audible differences between solders. It does require a degree of soldering skill though.
Just make up interconnects of solder, if you want to compare 2 solders make up two sets of interconnects using the solders instead of conductors, this way we're comparing a meter or whatever of solder rather than a number of joints. As I said it does require some skill.
Of course those who know it won't be audible won't bother and I for one will not waste my time, defending whatever my experience has taught me, consider this merely an alternative test method for those sufficiently curious enough, and not my personal stance for or against.
SC
SC
RF power amplifier transistors run at very low imedances and would reveal any non-linearity or significant resistance difference caused by solder ruthlessly under test.
They don't
They don't
Very good idea.Well those arguments never go away, same responses as well.
SC
One simpler/faster version of your test would be to mount 2 pairs of RCA connectors inside a metallic cabinet, as far as can be , say 10 inches, interconnect grounds with a piece of fat copper wire to put it out of the equation and join hot to hot with a 10 inch piece of solder wire or 10 inches of copper , selectable with a switch or even better, a remotely controlled relay.
Or use 2 pieces of solder as hot: one leaded, the other silver.
Pass audio through it alternating both materials, check whether:
is verified or not.I just could not believe the difference between the sound of the two... the one with the silver solder is just SO much better, both in dynamics, clarity, transparency, and all other aspects that you must really hear it to believe it. What was even more astonishing -and this is really hard to describe- that the bacground noise level of the recordings were reduced significantly.
Simple test.
By the way, 25 inches of solder is equivalent to, say, 1000 soldered junctions in series or more, so any effect , if existent, should be blindingly obvious.
Ok, then don't try to.To come up with a reasonable (scientifically proven) explanation is beyond my knowledge,
In fact, before searching for an explanation, the fact must first be proven to exist.
I do not troll, so calling me that was what I was unhappy with. I try to keep the discussion technical where possible, and was requesting something in support of your statement that cables sound different. If it's just your opinion, no problem.😉 Extending the "cables sound different" to solder was just downright incorrect.Oh my gosh. Read back man. I never attacked you. I tried to avoid further conversation with you and continue to do so.
I have some 20+ years old rosin flux core soldering wire which works perfecty well even of test piece of PCB which turned to dark brown.
What are the symptoms of aged flux? Solder not take to metal?
The flux won't activate the surface, so the solder balls up and rolls off. the metal just sits back, looks at me and says "really, that's all you got?"
My historical experience with solder is this:
1959-1970 60:40 used in dozens of kits, Heathkit and Eico, Dyna, and Fisher tuner. I even made a working oscilloscope. I ALWAYS had to worry about COLD JOINTS. They were commonly discussed and warned against in kit instructions.
1970-1978: SN63 (37) Eutectic solder. Goodby cold joints! It was great and still is.
1978 to today: SN62, 2% silver solder. Lower melting temp than SN63, but also Eutectic. Wonderful flow, shiny joint, minimum heat stress on components that are not similar.
Recommended: SN96 (4% silver) for special occasions, like cable construction, where similar contacts will be repeated over and over. Said to be slightly clearer, but it can potentially damage sensitive components, because of the higher melting point. I recommend only to fanatics! '-)
Indium solder, apparently the best, but $$$$$ expensive. Lower soldering temperature, etc.
This has been my experience, up to now.
I've used all of them and quite a few more alloys as well. The indium alloys have the problem of flux activation temperature. The lower you go, the more aggressive the flux has to be to clean the oxides. Also, there is a copper-indium alloy that is less dense, creates kirkendall voiding.
And yet, even after 2000 years, somebody blows up 150 million dollars worth of equipment all because of one solder joint.Soldering and solder materials is a subject that is studied heavily, there is a wealth of information out there, covering every aspect of soldering.....
I'm confused. Tin silver doesn't have a shiny surface finish like eutectic tin/lead. It's a wee bit frosty in appearance. I had to re-teach all the techs and the QA people because of that visual difference.What? You must be doing something wrong then. All the joints I make with silver solder are as smooth as butter and as bright as freshly polished flatware.
jn
I have over a kilo of SavBit Type 1 Multicore on a reel I was gifted over 20 years ago, It still has a shiny surface and works just as well as the brand-new stuff at work.
Every now and then I pull off a metre or so, fatigue break it, and coil it round my fingers.
Perhaps your storage conditions leave something to be desired.
I once got a bad batch of SN62 solder that would not work, due to the flux. One one example though. Later rolls of the same brand and type were just fine.
Indeed that's what it looks like.
Even the best solder (and SavBit's certainly excellent) ages and oxidizes. 20 years, really?
Either way, wiping the solder wire with a cotton cloth will wipe off most of the oxides.
Cheers, 😉
Cheers, 😉
It was started when I got it, about 2Kg5 remaining, you can see why it's taken me over 20 years to get this far.
This is just to say don't be discouraged from picking up a bargain at a yard sale if it looks OK. You can do a quick test by wrapping a bit of solder round a scrap of copper wire with the metal exposed and heating indirectly with a lighter. Don't buy any plumber's solder or flux tho' 😀 ...except where the alloy + purity is stated if you're thinking of using a solder pot and brass roller to tin your home etchings, and even then, use an electronics flux. Don't overheat the roller, if you've ever overheated a bullet mould, you'll know what I mean.
I keep a bit of solder tape in my wallet. You take a bit of solder and roll it flat with a glass bottle or rolling pin. Twist the wires, wrap with tape, apply a flame. Survivotech.
or very much more.........
By the way, 25 inches of solder is equivalent to, say, 1000 soldered junctions in series or more, ................
Since soldered joint have wire to wire/terminal contact, the length of solder between the touching wire/terminal is effectively zero mil/thou/0.00mm
The number of joints is therefore approaching infinity. Let's settle for an estimate of one million as equivalent to 25"/635mm of solid core solder.
jn
Yes, a bad joint or one prone to failure is always a possibility...but here we are talking about the different formula's of solder having an audible (and thus measurable effect on the sound, and 4% silver (again) lead free solder sounding clearer!) During the transition to lead free and even now tests are carried out on assemblies soldered with different types of solder, bad joints aside, I have never heard of solder affecting the signal, maybe at the mad levels you go to.
One thing I have been thinking about is the tolerance of components and the magnitude of change that would have in comparison to the type of solder used! I would suspect that this would have a far greater effect than solder types?
or very much more.
Here you are Andrew, you can work it out...Its Sunday morning and my head is not capable of any hard work, and if I was at work I would use a 3d model of an assembly (we actually calculate the exact weight of some assemblies in 3D for satellites, and funnily enough for data trackers/cameras to go on wildlife).
http://www.te.com/documentation/whi...Through-Hole_Reflow-Compatible_Connectors.pdf
If you reference it to a standard PTH IC pin in a finished 0.8/0.9mm hole, 1.6mm, an standard IC leg is a cuboid 0.5mm x 0.25mm x 1.6mm; the top fillet can be ignored (solder flat with the top of a PTH hole is acceptable) or add 50% of bottom fillet which can be calculated simply as a cone r 0.45mm h 0.75mm. A rough figure is 0.7-0.9mm3 per joint.
When the wire to wire is a mechanical connection the copper is touching.
Solder around that "touch" point keeps the air and water out.
The solder is not the electrical connection, the "touch" area is the electrical connection.
We are told repeatedly, that one should make a mechanical connection first and THEN solder the joint.
You can add 0.7cub.mm around the mechanical joint if you want, or just 0.07cub.mm and the resistance across the wire to wire joint is substantially unchanged. Further due to the "airtight" quality it remains so for many years/decades/centuries.
The solder will generally flow between the wires unless a gas tight mechanical join has been achieved. In fact to achieve an acceptable joint the following is required:
By the way that is from a NASA standard🙂1.Solder shall wet all elements of the connection.
2.The solder shall fillet between connection elements over the complete periphery
of the connection
Hmm- and as we know by now, the Apollo missions to the moon was just a fake produced for some obscure reason - all pictures shot in some studio or desert..... 😱 so how can we trust NASA spec's.....??
Jees - the madness never ends..... 🙄
BTW - the Apollos used wire wrap quite extensively........
He certainly demonstrated much more restraint than many of us could - guess even at 72, Buzz still had enough of the right stuff
Awesome😀
I now prefer lead free solder wherever water washing makes sense,
simply because its mechanically stronger. +Silver even stronger yet.
The only flux that works well is conductive, corrosive, water soluble.
Has to be very thoroughly drowned clean and very thoroughly dried.
If you are working on an old stereo, the required water washing is
just not practical for too many reasons to list.
I prefer leaded solder wherever washing with water is impossible.
Unfortunately the only no-clean flux I would ever willingly use is
rosin. And even then I would prefer to spot clean with a Q-tip or
whatever. Unfortunately rosin just doesn't cut the mustard at the
higher temperatures required for lead free work. Or maybe it just
burns up too fast to give sufficient working time for larger joints...
I would get leaded with silver and rosin if I weren't pinching pennies.
the silver will give strength to the lead, yet still melts at a temp were
rosin is effective.
Melting point, mechanical strength, and flux residue are differences.
There is no difference in the conductivity of properly soldered joints.
Some of those crappy no-clean fluxes leave a plastic residue that has
dielectric properties and can change the capacitance between pins of
an IC. That sort of parasitic capacitance could plausibly be heard, and
even plausibly make something sound "better". Though I would expect
the odds favor any random added capacitance sounding worse.
rosin is effective.
It may very well be, I cannot discount that possibility. Given the vendor, there is a possibility that the product was bad from the get-go. It took a while for me to learn that the specific vendor was inclined to purchase material rejected from other customers for QA reasons.
I have found that even plumber's solder can go bad, and again, I'm not sure why. The basement is constantly at 50% RH max, and at a constant 65 F, so having a tin of plumbers flux stop working was quite puzzling.
No, not even at the levels I work with.During the transition to lead free and even now tests are carried out on assemblies soldered with different types of solder, bad joints aside, I have never heard of solder affecting the signal, maybe at the mad levels you go to.
In a well designed circuit, it shouldn't. Sometimes however, the design is insufficient for tolerance issues, and parts need selection. My big concern with the OP was the fact that the higher temperature and longer dwell needed for lead free might have altered the component parameters a tad. A tight circuit could possibly be affected at the level one could hear.One thing I have been thinking about is the tolerance of components and the magnitude of change that would have in comparison to the type of solder used! I would suspect that this would have a far greater effect than solder types?
Another thought was, is it possible that the build physical design was responsible? Perhaps one build is more susceptible to ground loop currents or stray EMF? Without far more details from the OP, that would be guesses on my part.
jn
- Member Areas
- The Lounge
- Lead vs. Silver solder
