A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
2-Chip 1/2 Clock Delay - Recommended! response
Carlsor,
I would be very interested in what you are proposing.
Especially if you will install the surface mount chips.
I would additionally be interested in buying the thing "made" if that might be an option.
Hoe many of would need to subscribe for this to be worth your while?
Thanks for the offer and the work.
2SK246Y CCS HOLY GRAIL!
I put some 2SK246Y JFETS through my injected 10KHz 0.1V square wave signal tests on a scope.
The big square wave scope display is from the top (drain) of the JFET at 50mv/div. The JFETS were set up to have a voltage drop of 2.46V from Vd to the low potential end of the source resistor where it joined the jumper to the JFET gate. The signal then went through a 1000 ohm resistor to ground across which I could measure the ma and adjust the source resistance pot to measure .406V (.406ma). The Scope leads were placed across the 1000 ohm resister to measure the current regulating ability and transient response of each JFET.
The next Scope pic is for a 2SK246Y (2.43ma Idss) set at 5mv/div. Current regulation is near perfect with the smallest transient response spikes I have ever seen from a JFET. Several 2SK246Y JFETS ranging from an Idss of 1.79ma to 2.70ma were tested. The Scope displays were identical. Of course the source resistance had to be changed to achieve the same 0.406ma.
The right most Scope pic is for a 2SK170bl (7.47 Idss). This shows much larger spikes in response to the square wave.
Now to build some CCS boards with the 2SK246Y and begin the burnin process. I would be shocked if they didn't sound at least as good as the 2SK170. As I mentioned before, the 2SK246Y is very temperature stable in the 25-40C range. This appears to be the Holy Grail of JFETs for the DDDAC!
The scope pics are dark because I had to turn off all the CFL lights at my work bench because they added noise to the display.
It works! See pictures below. Took about 4 hours total to build and install.
Excellent work! Thanks for the pictures. I've had the bits here to do the modification for a few days but haven't sat down to work out what goes where. I think that's all pretty clear from your pictures. Brilliant :)
Certainly sounds a worthwhile addition :)
And the 2sk246y results look very promising too. I've had 4 arrive here this morning. Need to see how they measure and work out what resistors I'm going to need.
Tweak board sounds like a cool idea :)
Quick question: I have 120r I/V resistors rather than the recommended 133r, just due to availability of the rhopoint resistors I've used. I believe this makes my output quieter, but can anyone tell me by how much?
I have some new amps with a passive preamp and it's a little on the quiet side, so anywhere I can get an extra bit of gain back is worthwhile...
Doede, since you've hinted at possibility of a new board. I came across a mention of the DSD1794A, seems to be virtually equivalent to the PCM1794A, but with the additional support for DSD. Should be intresting.
Also would there be milage in exposing pin 7 for an external clock source?
Hi
It looks there's some good tweaks to be done here. I like the idea of adding the 1/2 clock cycle delay to bring my old main board up to the latest spec. I have a question regarding the main board voltage regulator, can the 3.3V unit be directly replaced by a 5V unit? If so is there a benefit of fitting a belleson as Carlsor mentions?
Hi
No question the additional logic chips are necessary can be run at 3.3 or 5v
