Daphile - Audiophile Music Server & Player OS
CHANGES on the September 16th 2014 version:
  • Player control application on local UI (optional)
  • "File manager" tool in web interface
  • Kernel upgrade to the latest stable version 3.16.2
  • Power saving improvements (eg. dynamic CPU frequency option)
  • Other minor changes (eg. RAM Disk)
  • Bug fixes
Update via your Daphile web UI or download from Daphile ? Digital Music Convenience for Audiophiles.
Any feedback is warmly welcomed!
Previous release (Sep 16th 2014) had a bug related to CIFS mounting when a username is used. It is now fixed and the new version is available.
Hello.
Daphile 14.09 does not boot from USB stick on HP T5720 thin client. Any idea?
Here are tech specs of my HP:
HP Compaq t5720 Thin Client (EG840AA) specifications - HP Products and Services Products
The power saving changes in the Daphile 14.09 versions seem to cause boot problems on some PC hardware. On the other hand some USB boot problems are due to the unetbootin in which case better use Rufus or Universal USB Installer. For the first case you could try the version available at web address:
You are able to upgrade the full installation of Daphile to this version as follows:
  • Access the Daphile PC using http://daphile/cgi-bin/Devel address on web browser
  • Copy the following link text (either x86_64 or i486 version) to input field besides the "Install" button
    http://www.daphile.com/tmp.poTGRr4CMo/daphile-14.09-b190546-i486.iso
    http://www.daphile.com/tmp.poTGRr4CMo/daphile-14.09-b190546-x86_64.iso
  • Press "Install" and restart Daphile PC after installation has completed
I don't recommend this version for the users who don't have the boot problems with the other 14.09 version.
The same procedure enables to revert the Daphile version back to 14.08 by using the following download links:
http://www.daphile.com/firmware/testing/daphile-14.08-b101214-i486.iso
http://www.daphile.com/firmware/testing/daphile-14.08-b101214-x86_64.iso
I try to have a better fix after my vacation next week (I'll be offline) and have the power saving settings as configurable options in the next public release.
Hi, 14-06 version works fine!
My wifi card Intel WM3495ABG is not recognized by Daphile.
The drivers are gentoo (Intel PRO/Wireless 3945ABG/BG iwl3945) Wifi - Gentoo Wiki but I do not have the skills to install...
I would release my directemet Samsung tablet with Daphile PC bypassing the box.
Pat
PS: Excuse my English: Automatic Translation
>Kipeta
Thank you very much for your help. I've used Daphie version from your link, but I think the main reason of my problems was that I had USB stick formated in ext4 file system. Fat32 solved the problem and now everything works fine.
Best regards,
Another happy user😀
Hello,
I would be very interested into room egalizer included in Daphile, with a calibration mike that can be plugged into the PC, like it can be done with a Behringer DEQ2496.
Do you know whether this is something that can be released in the next versions ? Thank you very much.
Rgds
Hello everybody!
I hope this is right place to submit my problem.
I used Fujitsu Futro s450 (http://globalsp.ts.fujitsu.com/dmsp/Publications/public/ds-FUTRO-S450-2.pdf) with newest BIOS available, 1GB RAM, 2GB CF. Daphile was instaled on CF. Booting correct, detecting internal sound card correct, playing through it also correct.
I try to connect external DAC (Amazon.com: MUSE USB DAC PCM2704 Sound Card Optical Coaxial Decoder USB to S/PDIF Converter: Electronics) with PCM2704 inside.
The Dephile detects it correctly. In setup I see both sound cards - internal and external DAC.
After cold restart (unpluged power plug) and reboot, DAC plays track selected before. When I change track while playing, DAC dying and stops play. After warm restart (software) DAC doesnt alive. Only cold restart helps. Different changes in BIOS setup didnt help (ie. deactive internal sound card). I also try different versiond of Daphile with no effect.
In other hand Daphile and this DAC running on "big" stationary PC do not have this problems.
USB in Fujitsu are smooth and handle both pendrives (up to 32GB) and external HDDs 2,5".
I tryed almost anything in setup but with no success. Could anybody help me or sugest where I should search? Thanks.
Regards from Poland
Tom
PS. Anyway, thanks for such good soft.
I got the web interface now Cypis but dont get any sound from any of the classical radio stations.
Did you try other then classical radio stations? What about music from pendrive? MP3, FLAC?
Do I have to set up the dac or anything else.
Almost every PCs have an internal sound card. This device have to be active in BIOS. Then Daphile detects it automaticly (in most cases 😉). Of course you can use another additonal sound card inside PC (ie. Creative, Xonar, M-track, etc.) or... just external DAC conected via USB.
If you still havent any sound from sound card or DAC you are in the same point I am.
Regards from Poland
Tom
This is what Daphile see:
Code:
  Card #1: HDA ATI SB
  Driver: snd_hda_intel
  Device ID: 1002:4383
  IRQ: 16 (PRY:80)
  Mixer controls:
    Config:
      Master,0,on
      Headphone,0,on
      PCM,0,on
      Line,0,on
      Line Boost,0,on
      Mic,0,off
      Mic Boost,0,off
      Capture,0,off
      Capture,1,off
      Capture,2,off
      Auto-Mute Mode,0,off
      Input Source,0,off
      Input Source,1,off
      Input Source,2,off
    Contents:
      Simple mixer control 'Master',0
        Capabilities: pvolume pvolume-joined pswitch pswitch-joined
        Playback channels: Mono
        Limits: Playback 0 - 31
        Mono: Playback 31 [100%] [0.00dB] [on]
      Simple mixer control 'Headphone',0
        Capabilities: pvolume pswitch
        Playback channels: Front Left - Front Right
        Mono:
        Front Left: Playback 31 [100%] [0.00dB] [on]
        Front Right: Playback 31 [100%] [0.00dB] [on]
      Simple mixer control 'PCM',0
        Mono:
      Simple mixer control 'Line',0
        Mono:
        Front Left: Playback 31 [100%] [12.00dB] [on]
        Front Right: Playback 31 [100%] [12.00dB] [on]
      Simple mixer control 'Line Boost',0
        Capabilities: volume
        Capture channels: Front Left - Front Right
        Limits: 0 - 3
        Front Left: 3 [100%] [30.00dB]
        Front Right: 3 [100%] [30.00dB]
      Simple mixer control 'Mic',0
        Mono:
        Front Left: Playback 0 [0%] [-34.50dB] [off]
        Front Right: Playback 0 [0%] [-34.50dB] [off]
      Simple mixer control 'Mic Boost',0
        Limits: 0 - 3
        Front Left: 0 [0%] [0.00dB]
        Front Right: 0 [0%] [0.00dB]
      Simple mixer control 'Capture',0
        Capabilities: cvolume cswitch
        Limits: Capture 0 - 31
        Front Left: Capture 0 [0%] [-12.00dB] [on]
        Front Right: Capture 0 [0%] [-12.00dB] [on]
      Simple mixer control 'Capture',1
        Front Left: Capture 0 [0%] [-12.00dB] [off]
        Front Right: Capture 0 [0%] [-12.00dB] [off]
      Simple mixer control 'Capture',2
      Simple mixer control 'Auto-Mute Mode',0
        Capabilities: enum
        Items: 'Disabled' 'Enabled'
        Item0: 'Enabled'
      Simple mixer control 'Input Source',0
        Capabilities: cenum
        Items: 'Mic' 'Line'
        Item0: 'Mic'
      Simple mixer control 'Input Source',1
        Capabilities: cenum
        Items: 'Mic' 'Line'
        Item0: 'Mic'
      Simple mixer control 'Input Source',2
        Capabilities: cenum
        Items: 'Mic' 'Line'
        Item0: 'Mic'
Card #2: USB Audio DAC
  Driver: snd-usb-audio
  USB BUS: 006/002
  USB driver: ohci-pci
  Device ID: 08bb:2704
  IRQ: 18
310 (PRY:80)
  Mixer controls:
    Config:
      PCM,0,on
    Contents:
        Capabilities: pvolume pswitch pswitch-joined
        Limits: Playback 0 - 128
        Mono:
        Front Left: Playback 128 [100%] [0.00dB] [on]
        Front Right: Playback 128 [100%] [0.00dB] [on]
  Device #0 (enabled): USB Audio
    Player process: squeezelite (PID:2379)
    Max sample rate: 48000
    Format: S16_LE
Interrupts:
             CPU0
    0:         52   IO-APIC-edge      timer
    1:          3   IO-APIC-edge      i8042
    4:          2   IO-APIC-edge
    8:         41   IO-APIC-edge      rtc0
    9:          0   IO-APIC-fasteoi   acpi
   14:     140122   IO-APIC-edge      pata_atiixp
   15:          0   IO-APIC-edge      pata_atiixp
   16:      91584   IO-APIC-fasteoi   ohci_hcd:usb2, snd_hda_intel
   17:          2   IO-APIC-fasteoi   ohci_hcd:usb3, ohci_hcd:usb5
   18:     421074   IO-APIC-fasteoi   ohci_hcd:usb4, ohci_hcd:usb6
   19:          2   IO-APIC-fasteoi   ehci_hcd:usb1
   42:      10436   PCI-MSI-edge      enp8s0
  NMI:          0   Non-maskable interrupts
  LOC:     170671   Local timer interrupts
  SPU:          0   Spurious interrupts
  PMI:          0   Performance monitoring interrupts
  IWI:          0   IRQ work interrupts
  RTR:          0   APIC ICR read retries
  RES:          0   Rescheduling interrupts
  CAL:          0   Function call interrupts
  TLB:          0   TLB shootdowns
  TRM:          0   Thermal event interrupts
  THR:          0   Threshold APIC interrupts
  MCE:          0   Machine check exceptions
  MCP:         11   Machine check polls
  THR:          0   Hypervisor callback interrupts
  ERR:          0
  MIS:          0
Realtime priorities:
    99  FF    15 139   - migration/0
    90  FF    60 130   - irq/8-rtc0
    80  FF   311 120   - irq/16-snd_hda_
    80  FF   307 120   - irq/18-ohci_hcd
    45  FF  2379  85   - squeezelite
    45  FF  2194  85   - squeezelite
    40  FF   817  80   - irq/42-enp8s0
    40  FF   310  80   - irq/18-ohci_hcd
    40  FF   308  80   - irq/17-ohci_hcd
    40  FF   306  80   - irq/17-ohci_hcd
    40  FF   305  80   - irq/16-ohci_hcd
    40  FF    58  80   - irq/19-ehci_hcd
    40  FF    52  80   - irq/15-pata_ati
    40  FF    51  80   - irq/14-pata_ati
     1  FF     8  41   - rcub/0
     1  FF     7  41   - rcuc/0
aplay info:
**** List of PLAYBACK Hardware Devices ****
card 0: Dummy [Dummy], device 0: Dummy PCM [Dummy PCM]
  Subdevices: 8/8
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
card 1: SB [HDA ATI SB], device 0: ALC262 Analog [ALC262 Analog]
  Subdevices: 0/1
card 2: DAC [USB Audio DAC], device 0: USB Audio [USB Audio]
  Subdevices: 0/1
Regards from Poland
Tom
Cypis
1 disabile card 1
2 try to enable mixer 1 AND 2
All output in both sound cards were set "on" (checkbox was marked).
IIUC the daphile-formatted info your playback device is the USB card.
Yes. I have two sound sources. Integral sound card and external DAC which Daphile sees as "USB sound card"
Regards from Poland
Tom
Hello.
Hi, A_Men,
I run a HP 5730 Thin Client on Daphile. I have found that in so far as the HP5730 is concerned, and this should also apply to the HP5720, you have to use the i486 iso and NOT the x86_64 iso.
The HP 5730 does not boot from any usb pendrive imaged from the x86_64 iso.
I suspect its because of the age of the CPU used in question which is not a 64 bit CPU.
I solve my problem. Now DAC works perfectly.
The solution was discovered by accident. I changed old slow CF by newest one with about 16-18MB/s transfer. This helps. Strange.
But found another problem. On static IP Daphile have problems to download radio stations lists. Got msg:
Slim:😛lugin::InternetRadio:😛lugin::_gotRadioError (78) Unable to retrieve radio directory from SN: Couldn't resolve IP address for: opml.radiotime.com
With IP by DHCP everything is OK. Any idea where to dig?
