hey X - I've got a mini K15 in the 0.55 scale ballpark for an 8" which might hold a 10" - could one get a rough idea of performance in that case where the front of the cone sees an ~7" diameter cutout? have to be careful not to let B102's cone slap against the baffle (IF it will fit the rear chamber)
hey X - I've got a mini K15 for an 8" which might hold a 10" - could one get a rough idea of performance in that case where the front of the cone sees an ~7" diameter cutout? have to be careful not to let B102's cone slap against the baffle (IF it will fit the rear chamber)
Not sure what your question is... You have a K15 scaled down to 8/15 (0.53x) and you want to put a 10 incher (B102) in it?
If that is your question, here is what you get:
Usable to 80Hz, needs a sub below 80Hz.
its 1/2" plywood, this size: 1.4 cubic foot external bulk at 18.625" H x 13.5" W x 9.625" D (sans molding) and is cutout for an 8" - can I get a pretty good idea of how it would perform with proper cutout for a 10" by rear mounting a 10" speaker over the ~7" diameter hole? do you predict good power handling with Delta10a or B102 in 0.55 to 0.65 size K? (got 1kw/c) - -would a 2X10" Karlsonator be a good project with regards to range and power handling? or does it get too tall/long? - (two 2.5" to 3" coil should do pretty well.)
oops -the external dims are ~18.7"H x 13.5"W x 11.5"D for ~1.7 cu.ft. external bulk and B102 fits pretty well centered over the existing cutout - got to dig for a camera. The plywood in this old cabinet isn't as stiff as modern 1/2" Baltic birch. If it really could hit 80Hz with power then would be a good substitute for larger front load horns. I'm pretty sure ~0.65 scale will do 80 with Delta10A. Sometimes its easier and better to add a sub or two than try to extend some drivers LF cutoff. That recent TQWT with 1260W Infinity is liked by TheJessMan.
the speaker which came with this little diy K was a weak motor Stromberg-Carlson
with a thrown together mismash of 1uF to a CTS KSN1005 helper tweeter w. 28R shunt, the new model of B102 does pretty well - drums have real visceral kick without even 1/16" peak to peak excursion - maybe better than some front horn such as my 100Hz hypex - its got promise in this tiny form factor - the old mahogany plywood cabinet is flexy and tweeter not optimum - a good sub or two and this might be a pretty good system for realistic spl in a small package. btw, the cutout for the 8 is such as it just barely hides B102's surround.
for those who want real dynamics and are willing to experiment, Karlson enclosures offer a good alternative to direct radiator and horn
hey X - what are some of the best small drivers for wide dynamic little K work? I've one Delta Pro8A - although it shows strong in the graph below, its less sensitive than a F6 L.Cao - but the Eminence will take more power - there should be some strong 10" - I want realistic drum sounds in as small of a package as possible (combined with a sub) at 18.6x13.5x11.5", my little K15 type even with the weaker/new B102 is impressive in its range.
Delta Pro8A in SK8 vs F6 L.Cao in a Karlsonator6 prototype - perhaps SK8's curved reflector and (small area) port are contributing
to the large spl variation
Have you looked at any B&C's ? Their 6 in and 8in drivers are pretty nice for sensitivity. Get the Nd magnet ones - cost a little more but are more powerful typically.
B&C 8NDL51 8" Neodymium Woofer
Faital Pro 8HX200 coax is also nice
http://www.usspeaker.com/faital%20pro%208hx200-1.htm
for a 4ohm driver, MCM has a good price on a Faital Pro 10" - its only rated 300W but that's not shabby - how does this look to you? The amp I bought recently is optimized for higher loads - rated 1K@8/1.3K@4ohm
I have some SN10 P-Audio 10" coax unused which might make pretty good little midbass Ks
Faital Pro 10 Inch 300W 4 Ohm Mid Range / Mid Bass Speaker | 10PR300C | Faital Pro
Faital10
my P-Audio 10cx IIRC has a bit stronger motor than spec and being neo, is pretty light
Here's SN10C's pdf http://bjl.audioconcept.free.fr/Archives/03_Caracteristiques_HP/P.AUDIO SYSTEM/SN SERIES/SN-10C.pdf
do you think it would work in this small K?
coaxial speaker
diameter in / 10/254 mm
Power RMS (W) 200
resistance (ohms) 8
resonant frequency Fs (Hz) 67.3
Sensitivity 1 W / m (dB) 94
overall quality factor Qts 0,455
equivalent volume Vas (l) 27.2
maximum displacement Xmax (mm) 2.8
Frequency range (Hz) 65-20000
diameter of the coil (in) 2,5
neodymium magnet material
HF driver (in) 1
Weight (kg) 3.1
here's SN10C's woofer graph - extremely blurry but believe the 94dB/1KHz sensitivity helps mark its window
it has a rise similar to Delta10A
SN10C coax
Delta10A
Faital10
coaxial speaker
Power RMS (W) 200
resistance (ohms) 8
HF driver (in) 1
Weight (kg) 3.1
SN10C coax
Delta10A
thanks - that might be enough - is a bit larger any more useful? - does power handling of the 0.55 size look good?
how much sub would you say is needed to subjectively balance out a little 0.55 scale pair?
Delta10a looks pretty strong
compared to the moderate strength motor coax, SN-10C
100Hz might do -besides a pair of SN10C, I've a pair of Delta10A, one new spec B102, 2 old 10G200, and maybe 2 new Beta10cx- a good sub would be needed - - what might one make which is reasonably compact to keep up with the little Ks and reach say 40Hz?
how far downwards does the cusp aperture shift tuning?
For a sub, don't you have that nice box Jessman made for your Alpine drivers? If you want 98dB sensitivity to 40Hz, and reasonably compact and good dynamics to match the K's, I would go with a tapped horn. The cusp stretches it about 10 to 15 Hz lower vs the slotted aperture.
There is the Keystone sub that is well liked:
http://www.diyaudio.com/forums/attachments/subwoofers/229178d1309290471-keystone-sub-using-18-15-12-inch-speakers-keystone_sub_dwg_corrections_2.pdf
With a Lab12 driver reaches 40Hz I think.
You can't go wrong with the TH-18 if you can handle the size:
http://www.diyaudio.com/forums/subwoofers/190635-th-18-flat-35hz-xoc1s-design.html
Predicted performance:
for a midbass module in a full horn system, RCA-Fan's Hypex70 could be used instead of a Karlson-coupler
but for impact and small size, I prefer K to horn.
what scale K15 looks best for Kappa12A? -
Thiele-Small Parameters
Resonant Frequency (Fs)45 Hz
DC Resistance (Re)5.41 ohms
Voice Coil Inductance (Le)0.77 mH
Mechanical Q (Qms)7.76
Electromagnetic Q (Qes)0.28
Total Q (Qts)0.27
Compliance Equivalent Volume (Vas)4 ft.³
Mechanical Compliance of Suspension (Cms)0.3 mm/N
BL Product (BL)15.2 Tm
Diaphragm Mass Inc. Airload (Mms)42g
Maximum Linear Excursion (Xmax)3.2 mm
Surface Area of Cone (Sd)519.5 cm²
for already made bass, I can use a Stereo Integrity SI15D2 bandpass box
Total Q (Qts)0.27
I just noticed this driver posted in another thread. Might be good for a K?
MONACOR INTERNATIONAL : SP-30PATC
- Full Range
- A Speaker that Kicks Butt in Large Spaces
