I am considering picking up this DIY kit offered on Madisound here: http://www.madisoundspeakerstore.co...0e-diy-kanspea-4-full-range-speaker-kit-pair/
I am considering buying the kit with the Fostex Special 50th Anniversary FE103-SOL Limited Edition drivers. Can I get some feedback about what to expect from these, how they sound, if it's worth the money ($188 to my door), etc. This will be my first full rangers and it will be replacing a pair of Energy CB5s in my office at work and will be powered by a DIY 50wpc TPA3116 amp/6N3 tube preamp combo. If they are to my liking, I will probably replace my B&W DM-601 S3s I'm currently using in my home office. I'd eventually want to find a low powered, small tube amp to run them. As for listening habits at work, I usually listen to blues rock, metal, classical, country, and jazz at lower to mid listening levels. Many thanks for any info!
Jared
Jared
Any one of these drivers in this kit would be a great entry-level experience into this fine hobby! I say go for it!
Larry
Larry
The 103 is an excellent driver of its type and has something of a cult following, especially in Japan (hence this SE version). It's not however ideal for heavier pieces when used in a small BR, although lower SPLs will ameliorate some of that. You'll probably find the balance skewed toward the upper end of the spectrum -if you like that of course, no problem, and it's not likely to be significantly worse off at the bottom end than the Energy CB5. They're also a little piece of history. I would however suggest you consider a larger cabinet, a different driver with a bit more bottom-end potential in modest box sizes, or even both, assuming you have sufficient space.
Either way, welcome to the hobby. You'll find it's not without interest. 😉
It's good on small acoustic, female vocals, early music. It's terrible (to my ears) on metal, trumpet sections (e.g., Frank Sinatra), big jazz horn sections, orchestral, unless it's at background "listening to the radio" levels. It just doesn't rock out without doing something or other unpleasant.
And it needs a sub. But other than those caveats, to me it's one of only three truly magical, ear-pleasing widebanders (of dozens) overall (in part because it nails the tone of sounds -- if you listen to TV, you might find yourself thinking that a cellphone, doorbell, knock at the door etc. is real rather than recorded). Wide dispersion, very pretty top end, many virtues, some vices.
But not versatile. Still, if it's magic you want, if you don't find it with that widebander (on the right material), chances are you don't like widebanders. I have two of those kits and for what they are, they are good. But a sub will be essential (especially because a sub makes low listening levels much more tolerable).
If you don't want a sub, an unfolded BiB would be the thing to try (in my limited experience). It's important that it be unfolded (or at the very least, inverted but unfolded sounds waaay better to me).
Thanks everyone for your insight! Scottmoose, where might I find a kit with a bigger full range kit? I am a bit on a budget and this is for my office at work so I am not wanting something too fancy. As far as needing a subwoofer, I already have a nice little Polk 10" woofer sitting under my desk so I am not too worried about a lack of low end, especially since my Energy CB5's only reached down to about 70-75Hz. I am looking for something to cover what is left...say 70-80Hz and above with a more lush mid and high end reproduction. I do want to eventually replace my AV123 Onix Strata Mini's that are running my main 2 channel system with some larger full range speakers. I am running all tubes and think it would be a heavenly match!
Jared
Jared
I think you'll be happy with those for office use. I once had a pair of FE103 based speakers in my office, and they were just fine for any realistic spl levels. Yeah, it's true the FE103 is not great for metal, but that is true of clean and dynamic speakers in general. If you're using a computer as a source, you can always EQ in a BBC dip type response, which will help.
Oddly enough, I found the smaller 3" FE83 was a bit better for rock, probably because of its higher Qts and lower efficiency.
I agree the FE83En seems to behave better in certain respects, and my theory was that whatever "sore spot" was getting shifted a lot higher in the treble, where it didn't matter as much. (I switch between those drivers but keep going back to the 103's for other reasons.)
So, that being said, would you think it might be a better fit and/or bargain to buy their 3" kit instead? Here is their 3" kit: The Madisound Speaker Store
I would be looking at saving almost $60 going with a 3" instead of a 4" but I am willing to pay the extra money for the bigger speaker. Also, the 3" kit only comes with either the FE83En or the FF85WK drivers. Sorry for all the questions, I just rely on your expert opinions and listening experience to guide me toward the best option for my situation. Thanks again!
Jared
Jared
Opinions will vary but personally, if I was using a sub at a desktop -- in that specific situation -- I'd get the FF85WK's in the smaller kit and save money and space (and it will sound lovely on the right material). It saves a bit of space (and the kit-boxes for the 103's could stand to be bigger for those drivers, in my opinion, i.e., are a bit too space-saving).
If you were building "freestanding" boxes for a hifi (vs. boxes on a shelf), personally, I like the 103's for that. Of course it's all funny because all the drivers mentioned are miniature compared to others, so we're splitting hairs somewhat.
If you were buidling a two-way with a big woofer, the choice might be harder (I think it would come down to the tone of each driver with the particular amp, so it's personal preference, but any of those would make good sounds).
The child in me says to buy the 4" special edition but the conservative side says go with the 3" to save money. I am no good at building wooden objects but I can soldier up circuit boards like crazy. I am wanting to eventually learn how to make speaker enclosures but as of now, I don't have the time or tools to build my own. I guess further down the road, I can find someone on here or locally to build some suitable boxes for either speaker. Aaarg, I hate decisions like this 😀.
Thanks for your input on these options rjbond3rd. It will help me with the final decision...
Jared
Jared
I am tempted to get a set of the special edition FE103, but they would need to be quite a bit better than the standard FE103 for me to prefer them over the FF85.
Also note that the boxes these come with should be considered barely adequate, and as well some optimization of vent length might be called for.
dave
If I had to do it over again (I started with the ff85wk version of the fostex kits) I would have gotten the 4" version. Even though I matched them with a 5" desktop sub I still wish I had more lows coming my way at face level.
I traded up fairly quickly from the fostex boxes, like a matter of weeks, to some uFonken boxes, and am working on building some larger boxes than those now. The project after that is for some even larger boxes that use 4" speakers. So you could say I vote for the 4".
That's my .002 since I started with the kit as my first diy speaker. (and I just bought a table saw so that tells you something about how I feel about DIY speakers)
Your choice, ultimately. Since you have a sub, the smaller 3in & 4in models should do for desktop use. The FF85wk is probably the pick of the small Fostex drivers, but the SE edition of the 103 should be interesting. Since the kit boxes are fairly standard reflex types, I'd probably be inclined toward the latter driver. The 85 usually gives its best in slightly different loads. As Dave says though, you may need to adjust the vent length slightly (not difficult) as the Fostex enclosures are often aligned along Japanese tastes which don't always adhere to those in the West. No reflection, just different cultures sometimes having different priorities.
Wow, that gives me a lot to chew on! 🙂 I think I am going to go with my inner child's instinct and just pony up the extra $60 and get the 4" special edition. Is there anyone on this forum that can at least cut the the pieces out for a bigger box and send them to me to glue together? Maybe I could just buy the drivers and then pick up a pre-cut box and put it all together. Again, I really appreciate you all taking the time to help me out!
Jared
Jared
The grass is ALWAYS greener, take the plunge and enjoy the rewards of DIY! You won't regret it, this is not a big investment and who knows where it might lead.
Larry
Larry
It leads to work-benches, table saws, and routers with router tables and learning about v-this and q-that and knowing acronyms like QWTL.The grass is ALWAYS greener, take the plunge and enjoy the rewards of DIY! You won't regret it, this is not a big investment and who knows where it might lead.
Larry
Ask me how I know
No doubt -depends how much bigger you want. The 103 was intended for use in back-horns, so you could possibly buy the existing boxes &c., then later, when funds permit, buy a flat-pack of, say Frugel-Horn 3 or similar. That should be a nice combination, although they'll prefer front-wall / corner loading.
That sounds like a good plan my friend!
Well, I ordered the P1000E kit today with the FE103-SOL drivers. I am really hoping that these will mate well with the TPA3116 amp/6N3 tube preamp combo I am supposed to be getting next week. Thanks for everyone's input!
- Full Range
- Fostex P1000E Speaker Kit?
