Because its SIMPLE class D , no good for power & HIFI .
If you want quality , use other shematics.
As per the jbl bpx1100.1 it should be called as power amplifier...jbl schema has shown it to be working at +/-61 volts on 1ohms load...indeed my amp with 1pair of mosfwt handles 2ohm stereo and 4ohms bridge mono at 30-0-30 volts and problem was i had small heatsink with this amount of load
I added a fan for forced air cooling and then everything was cool even on bridge mode using resistor load of 4ohms..
So i guess i can call it as power amp..it can deliver 500 watts per channel in 2ohms load if i add 2more pairs..
I will do it and get the results with higher voltage..
Sabir Nadaf
i will surely do.please do sir and post schematics and pcb layout
but i need a little help.
i did not get any of the protection schemas working with this amp.
can u share any idea for that?
Sabir nadaf
What protection you need? To protect speakers you must use relay shema. If you want overload protection , take any from AB class amplifier .i did not get any of the protection schemas working with this amp.
My opinion - make a NORMAL amp , with a good driver , and you'll have no problems and obtain fidelity and quality.[emoji12]
hi sir pls post a simple schematic with both protection available
Hi stewin,
Did u ever get any protection schema working with this amp??
For protecting speaker use upc1237.simple and great
i havent tried it but i think jlesters design will work
I tried doing this..but no success😢😢😢
just use irf9540n and irf540n and all will be o.k down to 2 ohms
irf9540n and irf540n failed again. But I found the culprit,It was the Inductor.
The Value of Inductor was less than 10uH, I Wound some more wire to make it around 30uH.Now the Amp works fine with 4ohms.
I am curious how low value Inductor failed the FETs.
I can hear a faint 'Buzz' from woofer, is it normal for Class D amps?
There should not be any noise..
My amp worked well with irf9540/540 even on 1ohm load with 35-0-35dc supply.
Yours should work even cooler.
Use 1uf capacitor and 30uh coil.
And do not use higher value smoothing capacitors. Just use 470uf/100v capacitors max
Hi all, been following this amp for a while now and decided to build one.
Of course I can order the T106-2 toroidal core, but I have plenty EI / EE ferrite available.
Only problem is that it is all PC-40 grade material (TDK) and I need about 5 turns to get to 30µH, which can not be correct. (even with air gap)
I've seen some designs in this thread with EI and ETD ERL cores anyway. Could
someone tell me which ferrite materials were used there?
Thank you.
Thank you.
PC40 is a good ferrite for inductors! EI33 can work up to 500W at 4Ohm load .
This I understand, but how to get 30µH with EI-33 PC40 core is a mystery to me. I know how to gap cores, I know how to measure inductance, but as indicated before, to obtain 30µH, I only need to have about 5 turns and a huge gapped core.
Is this correct?
Something about 30turns and a 3mm gap in the center or 1.5mm under all 3 legs of EI33
I'll give you link for a program for calculating inductors later , in 3-4 hours.
Hi Dimonis, that would be great thank you.
- Class D
- Ultra Simple Class D
