6L6GC instead of EL34
I have a Palcom TA-70 tube amp (same as Dynavox VR70) that I have been modding. Replaced all caps with high end ones, nice NOS RCA pre amp tubes. This amp uses 4 EL34's and there is enough bias range for 6L6GC tubes. Can I just put them in with a rebias or do I need to change more to be able to safely use 6L6GC's?
I have a nice quad of RCA blackplate 6L6GC's that I would like to use 🙂
Looking at the scematic, what should be changed for a better match, if needed?
The sound is allready amazing
I would set the bias to read;
Anode dissipation, say 25Watt, divided by the HT multiplied by 0,707 is the dissipation of the valve including the screen grid. The screen grid uses about 5% of the anode value.
So for a warm class A 27 Watt bias, set the voltage drop across the 10R cathode resistor to (27/420X0.707) 45mA = 450mV
For a cooler running Class Ab use 17/420X0.707 = 28mA = 280mV
The 6L6GCW or 5881 is on a par with the KT88. The best valve designed for high power audio.
I prefer around 35mA
This is very similar to the Dyna design. The phase splitter in this case is unbalanced, which is not a good design practice- you want anode and cathode resistors to be matched and equal. Even then, the drive voltage requirement for the 6L6GC will be straining things a bit, but you could probably get away with it. You'll want to adjust the compensation and lead cap for stability and bandwidth to accommodate the new tubes.
R35 should be 36k and matched to the cathode resistor (buy several dozen 36k resistors and find a pair that match as perfectly as possible, absolute value isn't critical). If your output tubes are decently matched, you'll get a significant decrease in distortion.
C17, C20, and R38 should be adjusted. This will have to be done experimentally using a square wave and dummy load. You want to minimize ringing while not killing the rise time, and then confirm stability by placing a few different values of capacitors (from about 0.5 to 5uF) across the dummy load.
