Dejan. As far as I can see there is no need for speed in regulators if the output dumpers are not included. I prefer simple series regulators in the Goldmund style. BD139/140 are seriously fast devices and cost pennies.
Shunt regulators do not do anything remarkable and often cause problems. Series with shunt voltage reference is good. I have used VBE multiplier regulator and was very pleased with the results. That is using the 0.7V BE as the shunt element. Most shunt regulators need an output capacitor to be fast so what's the point? They are fun to contemplate and that's about it. Under no circumstances have a regulator to the dumpers. If the
dumpers are up 10 V they will be obliged to become a regulator in themselves. Also that is a softer clipping option.
You know how I like to do it, I've posted it here often enough. As you say, a VBE multiplier with a zener diode for required voltage minus drop across trannie.
For ultimate speed, use IRF MOSETs, they are also cheap and easily available, but bear in mind the greater voltage drop across them.
I use MJE 15030/15031 rather than BD 139/140 for two reasons: one, they have a higher voltage rating and I generally like to use BJTs at least twice the rated voltage, and two, in my case, they are asked to dissipate over 3W of power, and again, I prefer to use something at least twice the actual requirements, so the BDs are too close a shave for my taste.
Is it worth the time and trouble? In my book, yes it is, beats the classic capacitor multiplier easily for sound quality. And the cap multiplier beats the usual resistor/cap combo just as easily. You reap all the benefits of separate PSU lines for the input stage, VAS and the predrivers.
What have you found in currently available electrolytics that you like better? I haven't tested any lower voltage ones for quite a while.
You may find that you have as many answers to this question as the number of people you ask.
My personal choice is simple and is determined by personal experience:
* for normal use, I use German made Fisher & Tausche capacitors, my most frequently used values being 10,000, 4,700 and 2,200 uF/63 or 80V;
* for "price no object" projects, I use ? made Siemens Sikorel caps. Question mark because some years ago, Siemens of Germany merged its capacitor production with Matsushita of Japan, so I don't really know who actually makes them at this time, and
* for PSU filtering, I use Wima MKT series, for signal Wima MKS series. If unavailable, I will use Siemens models, and Plessey also has some good ones.
I shy away from Japanese capacitors because they sound a little shrieky to me, at least the ones I tried from Elna, Nichicon at al., but I will use Panasonic caps. The other reason is that Japanese products are most copied in China, so my chances of getting a Chinese copy are far greater than with European makes.
Unfortunately, these days, that is a major concern.
Even replace the caps with larger ones, same 'quality' (whatever that means) can be audible. There are a lot of amps with marginal PSRR and a larger cap will increase the higher mains harmonics spraying into the amp. Could well be audible!
jan
Not likely if bypassed with a lower value metalized Wima MKT cap (e.g. 220 nF).
Even the smaller value caps tend to be missing these days. These days, the norm seems to be 10-22 uF caps, of unknown origins and quality, probably the chepaest they could lay their hands on.
Agreed on poor PSRR though.
Nah. Bypassing those electros is mostly based on folklore. Do the math - how 'bad' must a 10,000 uF electro be before 0.22uF starts to make a difference? And when it does, there is the inductance of the wiring from the caps to the load that prevents the 0.22uF to make a difference where it matters - at the load!
If they have to help they should be at the load not // to the electrolytics.
But, increasing the electrolytics will still increase the line harmonics spray, from a low impedance, and those 0.22uF's wont do anything against that.
Jan
Same as inductors for the psu, one big black art , bypass caps and inductor sizing,give it your best shot ...
Wayne, I gotcha!
I'm 61 years and 2 months down the road and I still hear 16 kHz on both ears.😀
Admittedly, 3 years ago I could hear 17 kHz, and now just 3/10 attemps, which in my book means unreliably low.![]()
I still got one good ear ... 😀
Removing the carbon black from the formula has one really significant and recurring value- the records will wear out much faster. And getting to charge extra for that is even better. I suspect the lower surface hardness will cost in HF response as well. No wonder "less distortion".
At times I realize I'm constitutionally incapable of competing in High End audio. I just can't turn off my BS filter and invent on that scale. If any of these companies were much larger they would be hauled into court really fast. California has a law that allows lawyers to sue companies in the "public interest" and keep the winnings if companies are misrepresenting their products. It can be a really painful experience to deal with.
Demain , i don't notice high frequency issues with my silent pressings , nor on the white DD Pressings , definitely not any less than the black ones. As to wearing out LP's , i have never experienced that also , how many times would you have to play a pressing to notice degradation ...
Buying special BS CABLES For 10K to hear your pre/amp combo as insisted by the manufacturer should hit your filter too , talk about needing to protecting the public
At first glance this makes no sense at all, in any case I would expect tape hiss on Axis:Bold as Love would be the limitation. I have several wonderful old EMI's where the tape hiss is clearly heard on fade in and fade out.
If I recall, they said that decoupling the motor from the chassis helped to reduce vibrations transmitted to the LP during pressing and made a clearly audible difference. It works in turntables.
Now there's a non-sequitur, I can't believe you actually said that. The nonsense here lately is hard to bear. They said vibrations while the LP cooled after pressing not recording.
Wrong. It can be fully modelled, and the results of the usual insufficient engineering precisely understood - makes it clear why much audio starts to sound rather unsavoury at decent volume levels - there are no mysteries!Same as inductors for the psu, one big black art , bypass caps and inductor sizing,give it your best shot ...
What is a mystery is why barely anyone takes any of this sort of stuff seriously ...
Sorry you feel that way. Here's a source, and the link. There's a similar statement in an actual Kassem interview somewhere in Stereophile several years back. I can look that one up as well, if you're interested. BTW, I have the highest respect for your work.
Quality Record Pressings - Wikipedia, the free encyclopedia
"And just as ambient temperature, humidity and variations in steam and water pressure affect the quality of a vinyl record, so do the minute environmental vibrations from nearby equipment. Unwanted harmonic vibration transmitted to the die during the pressing process causes distortion of the record’s grooves and other noise as well as other unwelcome changes in the physical structure of the grooves on a record. QRP uses custom-designed press isolation pads to mitigate the effect of these vibrations."
Yes, he does count on his potential customers being ignorant of the basics of molding and vinyl formulation.
I swear, this was an honest comment he made during an interview, not just hype. He spent tons of money and time on his business, and he seems quite sincere and well motivated. We should have more people like that, I think.
Right, sure.
Now, I don't personally buy reissued LPs, I have all the original pressings of rock, classical, jazz, etc. that I want, maybe too many actually. But it's heartening to see interest in good recordings, especially from novices and young people. After all, the old master tapes will be worthless some day no matter how carefully they're stored. It's nice to have fresh pressings available of popular recordings so that people can hear them with good quality without all the noise and distortion on old, worn out copies.
I believe in the efforts to make a better vinyl record are real and useful. Not everybody is a 'liar' in the audio business.
Up Hill Rayma , up hill, take the cake ..... 🙂
We should send them (Kassem) an Email, less get to the bottom of clear vs black vs white vinyl , does the black carbon really add to surface noise ...
That's true, it's the 95% who give the rest a bad name.
I'm used to a university research environment where people have very strong opinions on many things, and often disagree intensely. It doesn't bother me at all.
- Member Areas
- The Lounge
- Sound Quality Vs. Measurements
