Ironamp Video Posted
Be careful old Sanken's can be transformed toTokin SIT 's
i have found a source , do you think it is genuine ones?
2SK180 TOKIN Field Effect Transistors TO-3 – 1pcs Refurbished | Sun-Pec
Hello Juanitox. I have some pieces from this source. I used ebay, but when I received them invoce was from sun-pec. I used lamp circuit to obtain its curves, and I got the same curves that Mr. Rothacher. This transistor can be very interesting... Its curves are similar to PASS SIT 1, I think.
a high current tube rectifier will drop a lot of voltage, waste of power , and add of heat ... we are hot enough with the 2SK82 😀 tube rectifier are nice with low power low cap value in the power supply but with 100000UF CRC who really cares rectifier sound ?
First off, it's bound to be a depletion mode part, so hook it the Drain (case)
up to a +12 volt/2 amp or so power supply, put a 10 ohm power resistor or so
from Source to Ground, and attach the Gate to Ground through a 1K resistor,
and then report back what voltage appears across the 10 ohm resistor.
Make a point of getting the G and S pins correct.
