First One - mosFET amplifier module
Hi ,don`t know how to hook it up really ,there is no Plan with it for Pin Out.Just fit everything in a new housing with better Heatsinks and one SMPS first,but enough Place to put a second one in.
Hi Dirk
SMPS1200A400 datasheet with connection diagram you can find here.
DC sense is connected to shutdown function pins - connector J4: pin 9 (-), pin 10 (+)
Connection sch will be published here before anyone will receive DC sense, so no worries at all.
Regards L.C. :cheers:
DC Sense kit GB
danny_66 4 DC sense kit
Theodosis O. 2 DC Sense kit
Brianco 2 DC Sense kit
quan 4 DC Sense kit
flyboi 4 DC Sense kit
ZZoran 4 DC Sense kit
giannettino 2 DC Sense kit
Pinnocchio 2 DC Sense kit
Catal 6 DC Sense kit
Rick G. 2 DC Sense kit
Eric06 2 DC Sense kit
Audionootje 4 DC Sense kit
BYRTT 4 DC Sence kit
Dmitry Nevozhay 2 DC Sense kit
kimon 2 DC Sense kit
fredlock 2 DC Sense kit
loek 2 DC Sense kit
Sum of 50 DC Sense kit at the moment. Proformas send. :up:
DC Sense kit GB
quan 4 DC Sense kit
loek 2 DC Sense kit
taccodude 2 DC Sense kit
Sum of 52 DC Sense kit at the moment. Proformas in sending. :up:
P.S. Update: Proformas already sent. After payment confirmations received, goods will be shipped promptly. :up:
Hi, LC,
Could add me for 4 DC sense kit? Thanks! :)
quan 4 DC Sense kit
loek 2 DC Sense kit
Mark Verhoeven 2 DC Sense kit
jokari69 2 DC Sense kit
James 4 DC Sense kit
Sum of 60 DC Sense kit at the moment.
James
Today I finished FO and I got a Problem with it.You can listen with normal level and after that , the Amp goes on and off.Can SMPS be broke?
Easy to figure out, looking at your rails, first.
And, if you can see a cutoff of the power supply, to test-it with a power resistance for to little less than max amps it is supposed to provide.
Probably a stupid question (I am a newbie in this)... Is there a quick guide on what connections I need to make? I think I have it figured, but just want to make sure that I can get this built. I would very much like 12V trigger in/out functions, and my understanding is that the SMPS that has been mentioned here does not have the 12V out capability ? The reason is that I would quite like a monoblock arrangement and I need to modify my current DAC/pre-amp to put out a 12V trigger out > trigger in on one monoblock > trigger out to other monoblock.
