Shigaclone MKII Black - The builders Thread
Now about your selfmounted MKII.
I still didn't get an answer on which transisitor do you use.
Tibi
Sorry Tibi.
I didn't understand you were waiting for input, my apologies.
Q1 = Marked PJ66 M3A
With the scope I found that the voltage on collector is 4,6V and when activated it drops to 4,4V.
The only one I know of with a macrolens is on vacation... I can take anothe iPhone photo if it is of any gain.
Sorry Tibi.
This is normal. Q1 get saturated under normal operation and entire laser curent is dictated by Q1Vbe and emitor resistor.
While TOC search you should see a white light with a camera, right above laser lens.
Tibi
Well this is something new.
It never hapen before to have a dead mechanic due laser.
I would susspect: laser protection solder bulb not properly removed (use a multimeter and measure exactly over), ribbon cable twisted or broken, main board connector have short or bad solder.
Tibi
Tibi
Thanks Tibi. I measured the static protection - no short. I'll wait for the replacement and have high hopes as there is no toroid rumbling around in this shipment 😉. The rest of your proposals are checked and seems to be in order. Suppose the laser and its circuit is in order. How does the MCU decide when to light the laser or not? What signals does give the input for the decision?
v1 and v2 ps
hi tibi,
before i make a big mistake, please verify on the pic attached that im doing the right install for v1 and v2 power supply.
hi tibi,
or this one? just making sure im doing the right install.
Yes, this is correct. For more detailed info related to miniregs pin assignment vicol audio : Low noise LDO mini regulator
V1, V2, V3, V4 is 8V pad not GND. Anyhow you'll not use this as power input, due your super-regulators will need a higher power supply above 8V depending on the type you use - refer to manufacturer super-reg datasheet.
As mentioned by Danzup, in case V1 and V2 are mounted, respectively L2 and L3 must be removed.
Tibi
hi tibi,
Pin1 of J6 is GND for your superreg !!!!
Middle pin of V1 and V2 print on Shiga is where you connect +5V output from your superreg . Remove L2 and L3 .
Attention !!!! This voltage ( delivered by superreg ) must power on and power off at the same time with V3 and V4 .
Failing to do so and Shiga will not work .
See attached corrected picture .
Use that pin for GND of superreg (pin1 of connector J6)
do not connect other wire !
If you do not understand please take pictures and ask here if connection are correct prior to power on Shiga.
installed burson series 2 superreg on v1 and v2 and i would say that it was a big improvement. very black background, imaging is better, more 3 dimensional. very airy..
thank you tibi, and to everyone for the support
