All boards have now shipped out for the Slewmaster project that is spearheaded by ostripper, thread located >here<. There are no plans for more boards on my part, but member evanc is conducting / continuing the GB here for the latest iteration of the 5P OPS boards.
CFA-XH IPS - Out of stock
Symasui IPS - Out of stock
Wolverine IPS - Out of stock
Spooky OPS - Out of stock
'Mini' LMOSFET OPS - Out of stock
2 Pair OPS - Out of stock
5 Pair OPS - Out of stock
The 'Mini' LMOSFET OPS are 3" x 4" (76.1mm x 101.6mm).
The SlewMonster 2P OPS are 3" x 6.3" (76.1mm x 160mm).
The SlewMonster 5P OPS are 3" x 9" (76.1mm x 228.4mm).
The CFA-XH IPS are 3" x 3.5" (76.1mm x 88.8mm).
The Symasui IPS are 3" x 4" (76.1mm x 101.6mm).
The Wolverine IPS are 3" x 4" (76.1mm x 101.6mm).
The Spooky IPS are 3" x 4" (76.1mm x 101.6mm).
I will also do my best to find and post relevant links from the development thread here as well so folks can find the schematics and other pertinent information as well.
SlewMonster OPS Drill Templates - 2P and 5P Versions
SlewMonster OPS Schematic
SlewMaster Gerbers and Excellon Files
Jason,
Put me down for 5 IPS and another 3 OPS...I take it the OPS is the same board you made available initially ?
Best Regards,
Theo
Best Regards,
Theo
Jason,
Best Regards,
Theo
Electrically identical and same overall dimensions, just some minor 'push here, pull there' on some parts, primarily in the driver / pre-driver and power input / speaker output areas. These changes were aimed at widening the selection of capacitors that will fit the board and allowing a better fit for larger resistors in the Zobel. I will be putting up a new drill template soon, the hole for the main heat sink mounted bias transistor moved 0.100" 'right' and the corner mounting holes are each 0.050" closer to their respective edges.
tjencks - 3x OPS, 5x IPS - Request Acknowledged
arthur - 10x OPS, 10x IPS - Request Acknowledged
kindhornman - 2x OPS, 4x IPS - Request Acknowledged
@arthur - I will check with the post office to determine if there is any advantage to splitting your order or not, the weight ends up outside the published rate sheet I have. I will let you know. Thanks.
spind - 4x IPS - Request Acknowledged
ImmortalZ - 2x OPS, 2x IPS - Request Acknowledged
evanc - 3x OPS, 3x IPS - Request Acknowledged
triplej - 4x IPS - Request Acknowledged
Ranchu32 - 2x IPS - Request Acknowledged
nikosokey - 2x IPS, 2x OPS - Request Acknowledged with special request
I will get PMs out with shipping prices for most of you folks this evening and provide you with my PayPal information. For those who have made requests could you kindly forward me your shipping addresses (some I have from prior shipments but I would still like to confirm the details please). Thanks for a good start to this project!
Currently:
arthur - 10x OPS, 10x IPS - Shipped
spind - 4x IPS - Shipped
ImmortalZ - 2x OPS, 2x IPS - Shipped
evanc - 3x OPS, 3x IPS - Shipped
triplej - 4x IPS - Shipped
nikosokey - 2x IPS, 2x OPS - Shipped with special request
There's room for more participants if anyone is interested, just post requests here or send me a PM. Thanks.
No problem Quan.
quan - 2x IPS, 2x OPS - Request Acknowledged
OMG I hope I didn't miss out!
2 x IPS and 2 x OPS please
Nope, you have not missed the bus! I will send you a PM.
- Group Buys
- SlewMaster Project Boards
