If memory serves, Otala & Lohstroh postulated that an amp should be running in pure class A up until -17 dB of nominal power.
For a nominal 25W continuous power amp, that's half a watt.
What I was saying was that, combined with a loudspeaker that has an efficiency over 90dB/W/m and an easy impedance, it's as good as a class A amplifier.
(an often read half-wit definition of a class A amplifier, is that dissipation is as high as nominal power output. Just the output stage devices of the 25W Otala already dissipate 28.8 watt)
Unfortunately, the engineers are not heard often enough, they take a strictly back seat to the bean counters and whizz kids babbling about "product niches", "competitive prices" and "aggressive marketing". Engineers deal with real world things, often measurable, not pie-in-the-sky concepts.
which brings us to the incredibly important point: if they be that way, and live that way, then they have no voice and are entitled to no voice or opinion, whatsoever, in the area of discovery. To keep their dogma to themselves.
it is an entirely logical and correct point to say so.
If they wish to comment on discovery and experimentation/observation, they are required to put in many a year of exploration and openness without the slightest form of dogma or factualization in their minds, whatsoever. to do this before a single comment emerges from them on discovery and invention. A place where dogma cannot exist as it inherently snuffs out discovery before it begins.
Again, entirely logical and reasonable.
So, in effect, if a an engineering mind can put down the bibles...and move away from being a mid-level cleric, and stop writing up papal bulls for executing blasphemers of the dogma...then we can talk exploration.
KBK,
Don't confuse the norm of an engineer's work and the work of a so called engineer/researcher. Two very different disciplines that overlap. Both require a very broad based education to perform their duties and those skills so often overlap, but the engineer is tasked with a specific end goal in mind and uses their education to performs those tasks to the highest known standards. The researcher or inventor has to look past their known knowledge base and try things that they have no preconceived notion of the outcome, they have to allow for failure and the unknown. More is often learned from the failures than from the easy successes.
