QUASI Amplifier for Beginners
still going....
please enlighten me master 's of diyaudio
dear sir,
as yur image u use tip41,tip42 in place of mje340,mje350
tip volts are 55v where as mje voltage is 300 volts,
i also want to make this amplifier plz suggest me for hi-fi amplifier.thanking u.urs evr masood
Hi radio ,
I have search for you an better schematic , also tested one . I have done small changes for 2SC 5200 as finals .....🙂 I hope you like it .
Regards Alex.
dear alex,
i found your this circuit and pcb can i make this. please send me more details corrections etc. u are my ideal.if any one make this kit plz show .i will highly oblized thank u.yours ever masood
Hi Mile!
I made this Quasi amplifier (picture below), but two things bother me: Why security diodes 1N4007 are connecting to the PCB in front of the fuses and why 0,33R/5W resistor is connected to the collector output transistor (2N3773), not the broadcaster?
Mile you do not need to make a correction?
Waiting quick response after I made ​​amplifier!
thanks and cheers
P.S.
Posto slabo mi ide engleski evo prevoda na Srbski:
Izradio sam ovaj Quasi Amplifier (slika dole), no muce me dve stvari: Zasto sigurnosne diode 1N4007 su povezane na PCB ispred osigurace i zasto otpornik 0,33R/5W je povezan na kolektor izlaznog tranzistora (2N3773 povezan na negativnoj grani), a ne na emiter??
Mile molimte odgovori na pitanja da ne treba da napravim korekciju?
Cekam brzi odgovor posto sam izradio pojacavac!!
Hvala i sve najlepse!
dear sir
would you plz share this pcb and circuit details,because it is different .
thanks your ever
