Try .02 ohms and see the change that is a high value for film polyprop caps.thank you Triodethom
never heard of a 1626The standard Darling tubes, I suppose: a pair of 1626's and a 12SL7GT.
I have a PCB I laid out for the Darling and built the chassis to drop it in.
It is very clean. Probably because the heater voltage is DC.
Hi, I am a newbie. Can someone recommend an amp package kit to start with? This way I don’t have to first look for a schematic, then transforms, tubes…Since I am a beginner I am open to suggestions. If I am in the wrong thread please show me the way. I’ve looked through other threads, most places I have no idea what other are talking about. Thanks. Looking forward to learning something new here.
If you do a search on "Darling tube amp" you'll find plenty on the 1626. Some might argue the 1626 is the Darling.
It is a beautiful "bottle-style" triode made for, I believe, a radio for a WWII-era bomber plane. The government unloaded a ton of the NOS tubes when solid-state swept in.
They show up on eBay fairly regularly — if you buy them in bulk (a dozen or so at a time) you can get them for between $5 and $10 each.
I'm hoping to put together a few Darling kits based on my PCB, FWIW.
Darling I built:
Oh Darling ...your Bikini is wonderful !!!
PSU for EL300PP
What is the power output of this amp? Looks nice and simple.
Well done!
The question under the scheme: not too high raised one of the heats?
27k resistor is missing
Suwaned
amp Looks great!! Single ended or Push pull? how many watts?
Phil
Hi Phil,
Thank you,
this amp is Single Ended, I made this power by looking at the pages of Jim De kort. "VT52".
Driver VT25 (replace 71A) and final RS241.
Tube Rectifier : RGN 4004.
regards
- Tubes / Valves
- Photo Gallery
