Dear all,
I am using tapatalk with my Samsung Ativ S (Windows Phone 8) and while I can access the Forum with my ID incl. opening the subforums and threads the replies are not loaded. Furthermore I can't see my subscribed threads while the "participated" are shown.
I don't have this effect with other Forums (e.g. HEAD-Fi) nor did I encounter this problem with tapatalk for android. Any one else having such problems.
I am using the latest version of tapatalk for WP8.
regards, Daniel
regards, Daniel
Tapatalk stopped working completely on Android today and was not working right on the Win 8.1 X86 version as well for some time.
Same for iOS 7.1 - other forums still work, so it seems to be an diyaudio issue ("Server error occured: Call to a member function fetch_instance() on a non-object (get_thread.php(996) : eval()'d code:11)
Same here, I can browse threads that I haven't replied to but any thread to which I have responded gives the error rollingtube mentioned. Oddly yesterday was the first time that I could find DIYAudio in the Tapatalk software. Dunno why that was but I was excited, until it didn't work.
Edit: Also, might want to change the title of the post to Tapatalk Issues. Since it affects more than WP. Attached a copy of the error message.
Still getting the error on both Android and Win 8.1. Exact error as above. I tried removing and replacing the forum on both platforms with no joy. I can navigate to a thread but cannot read it.
Just a thought-do you have the current version of Apache and PHP on the server?
I'll post on the tapatalk forum but here are a few links that might help. They are for the same problem in other vBulletin forums:
Tapatalk cannot open threads any more!
vBulletin 4.0.x Unparsable Result error - Forum Runner Support
Here is what I found that seems to match the problem:
https://support.tapatalk.com/threads/4-1-0-server-error.11732/#post-66487
Same issue here starting this week with diyaudio only (head-fi still works good), using lastest ios 7.1.1,
I also removed diyaudio then added it back still no luck.
"Server error occurred: 'Call to a member function fetch_instance() on a non-object (get_thread.php(996) : eval()'d code:11)'"
Same here.
iPad Air and Tapatalk 2.7.1.
- Site
- Forum Problems & Feedback
- Problems with Tapatalk for WP8
