Part of the A10.x paid planset.
No direct comparison yet, both are good, but i expect the Mar-Ken would have a slight edge.
dave
Thanks for the info. To buy the Alpairs with the enabled tweak is intriguing!
I've tried the FXL with the Alpair 10P only and initial impressions are favorable - The low end is plentiful (a lot 🙂), mids are very neutral and clear; the top might sound slightly laid back depending on the amp - I am guessing that the Alpair 10.3 metal would have a brighter and more extended HF response?
Thank you, I fear that the paper cones are maybe too polite in the HF for my taste - at least with pop/rock/funk/fusion. Beside that the linearity of the 10.3 is unmatched by any other FR driver over 5".
having the choice of drivers, and several enclosure designs that can fairly easily accommodate the differences in tuning is certainly a bonus
Guys any news on the plans?
I might also have the opportunity to get some Audio Nirvana 6.5 cast for peanuts. You think the XL would work nicely with them without any significant mods? Probably not, but I had to ask...
More or less ready to go. Forward me your PayPal confirmation for you donation todiyAudio and i'll get you the plans.
dave
Probably a stupid one, but are FHXL more sensitive than FH3?
I use a pair of FH3 with SE 45 Triode, little bit on the short side of power 🙂
Yes. In all back loaded cabinets, that's a direct function of driver sensitivity, so assuming the 10P for example, they're a conservative +3dB over FH3.
Thanks I will probably build a pair.
I can't find the sensitivity of the driver, any idea of the final sensitivity of the FHXL?
As Scott says, the driver sets the sensitivitiy.
With A10p FHxl is therefore about 90 dB, wuth A10.3 about 87 dB, FH3 with A7 about 85 dB, but if you have FE126En about 92 dB.
The horn only has gain at low frequencies and you reduce any excess away with damping to give a balanced response.
dave
Dave beat me to it. But what he says. Varies with the drivers, so assuming they work in the box, their nominal sensitivity is what you end up with.
so low? I'm impressed by the capacity of my mighty 1,8w amp to move the A7!
Due to the absence of xover?
The only way you can exceed the driver's own sensitivity across a wide BW is via front or compound loading. Back loaded cabinets of any kind only function over a narrow BW at the bottom end of the audible frequency range.
As for the other, no XO = no losses, although these are typically quite small in a competently designed filter with reasonably low resististance components. More a case of depends what your requirements are in terms of SPLs and the baseline you use for comparison. People are often surprised how little power is needed to make a relatively loud noise, even in relatively low efficiency systems. Where a low power amp may become more problematic in such systems is when asked to reproduce material with large LF dynamic range since it will have less in reserve.
Well, there it is. Good to know you're finding them fairly satisfactory even against the Altecs. 🙂
You know, it's a matter of coherence, too much parameter to get those old fashioned speaker satisfactory. Xover are a nightmare, position as well, huge cabinet are not stiff......but you know the story 🙂
just made some A/B comparaison with Altec, the most chocking is the rapidity of the FH vs 515....ok less pression, but so quick bass....
Are the XL flat packs shipping to USA yet??
The 2 beta flat-paks shipped to CO & CA. First production batch is slowly being put together, but we likely won't see tham until after Chris comes back from holiday (end June, early July?).
dave
- Full Range
- Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, more
