Rogers LS5/9
I don't know why you'd want to exactly clone the LS5/9 as it is quite an old design. Modern drivers could potentially get you a better result with a less complex crossover. Go through the BBC research papers and take the best of the ideas, certainly - maybe also look at the work Harbeth are doing.
In any case, without a reference for voicing the crossover you'd never get all the way there. The BBC models are assessed against a reference before a licence is issued.
Harbeth have worked wonders in updating the LS5/9!
6moons audio reviews: Harbeth M30.1
Nobody, especially Alan Shaw of Harbeth is going to give away the many design features of the BBC sound, but I've already suggested a good modern SEAS polycone. Tweeters are a matter of taste and debate, but Harbeth use a metal SEAS unit on a complex crossover. Cabinets are thin wall ply for sure.
I can suggest no finer reference than my own on thin wall construction:
http://www.diyaudio.com/forums/multi-way/223174-interesting-read-i-found-lossy-cabinet-designs-harbeth.html#post3234256
8" bass and tweeter is a delightful combination done right. KEF did it years ago to near perfection, although you can adjust this circuit considerably, it is the right idea:
on 8ohm woofers and possibly 6-8ohm tweeters that will cause significant dip on crossover TF
