Thinking about it a little more, I think I would see if Aluminati to help you build bridged monos if I wanted to go that route. I do like their cases.
Bob
Bob
In less than 2 ohm, birding won't give you more power as current will be the limiting factor.
Bridging should in that case not go louder, but it might sound different. Theoretically even order harmonics should be equalled out however in the real world we are already at such low distortion levels that other things, like implementation, might govern the outcome...
Actually, a less than 2 ohm load would be seen as a less than 1 ohm for each side of the bridge, for which the amp is not specified. It probably still work, but you are pushing beyond what the amp has been specified for.
For 2 ohm speakers, I would stick with a non bridged ncore. If ultimate power is the major concern do a UCD2K instead 🙂
cheers,
cheers,
You will still get double the power - current stays the same, voltage doubles.
Agree. Not a good idea.Actually, a less than 2 ohm load would be seen as a less than 1 ohm for each side of the bridge, for which the amp is not specified. It probably still work, but you are pushing beyond what the amp has been specified for.
That is my recommendation too. If you go for bridging, you'd better really know what you are doing.For 2 ohm speakers, I would stick with a non bridged ncore.
Julf, we agree on the conclusion, but I fail to see how you can get more power if current is the limiting factor. The speaker still follows ohm's law and two ncores in bridge won't be able to drive more current than one. 24A peak is what you get with ncore400 bridged or not.
cheers,
24 A, 25 V -> 600W
24 A, 50 V -> 1200W
Bridging doubles the voltage across the load.
24 A, 25 V -> 600W
24 A, 50 V -> 1200W
24A, 25V -> 1.04 Ohm
24A, 50V -> 2.08 Ohm
Different load. Bridge would not handle 1.04 Ohm at 50V.
24 A, 25 V -> 600W
24 A, 50 V -> 1200W
Only if you have twice the load. In this case you don't.
In a bridge remember that each side only see half the total load meaning only half the voltage drop too. I repeat: When current is limiting, you get the same current and voltage = same power.
Please see my calculations in the thread that was liked to a few posts ago.
Duh, yes. Brain fart.
You are right. If we are already in current limit mode, and the load impedance doesn't change, bridging won't add any power.
You are most welcome Julf.
Glad to be of help
All sounds a bit excessive. How much power can a 1.7 handle? Into a nominal 4 Ohm load there's about 400W available. More useful to have four modules and use an active analogue or DSP crossover I should think. Just a thought...
Indeed. The first step would be to check in the nc400 is actually clipping.
So the best best is to use smps1200 with Bridged connection as
For bridging, each nc400 require at least one smps600. That is two per side = 4 smps600 for stereo.
One smps1200 per side should be sufficient -and will be cheaper 🙂
+1
Actually, since hypex launched their SMPS3k in lower voltage versions, the SMPS3kA400 would be the cheapest way to power a bridged nc400 stereo amp... Though not by much (in comparison to two smps1200A400)
cheers,
cheers,
ty for the suggestion..as you can see i already have 6 Ncore with 6 smps600 ...so what i get it is i can use two smps600 with 2 ncore and get close to 800w on 4 ohm ....
am i correct to think that??
V
V
Not at higher frequencies where your speaker impedance goes too low for a bridged pair. But even a singe nc400 will give you 580 W into 2 ohm. The difference between 580 W and 800 W is less than 1.5 dB.
As we keep saying, first step is to see if you actually get a single nc400 to clip when you play at your loudest setting.
V
If you already have 6 sets of nc400/smps600 then stay with that.
Expect to get about 800W in 8 Ohm and about 1200W in 4 Ohm.
(within the current limiting you should get twice the power of one nc400 in half the impedance. As each nc400 deliver 400W/4R and 600W/2R, you'll get 400+400W in 8R and 600+600W in 4R)
For loads below 2.7 Ohm you'll face current limiting (before voltage limiting) and won't get more power from bridging than running single ncores...
Hope this helps 🙂
Hope this helps 🙂
can you tell me what is the connection between two smps and two ncore...
V
- Class D
- Hypex Ncore
