Question: Acceptable DC current in push-pull output transformer due to tube mismatch?
If the PP tubes have exactly the same idle dc current, but different conductance performance, then there will be an effective dc offset over a waveform cycle.
With respect to BH curve locus, one side of the excursion will move waveform peaks in to worsening linearity region before the other side - which is the same distortion related mechanism that is being discussed when there is a dc idle unbalance but otherwise perfectly matched valves.
This works quite differently to a standing DC balance since it is proportional to the output signal rather than been fixed in the case of the DC imbalance. That means DC imbalance produces a fixed quantity of relatively high distortion, but AC imbalance produces a small to negligible amount at normal levels - only rising to levels comparable to DC imbalance at large signal excursions.
It a question of choices really - but the choices are not really equivalent.
Shoog
When does AC imbalance become objectionable? How often does it to be adjusted?
Exactly my position, my experience is that it doesn't become significantly objectionable right up until you have to replace the valves.
I have to wonder how the DC bias point and AC amplification behaviour are related. It seems to me that they must track to a large degree and so if you correct one over time you also help to correct the other. Am I wrong one this, and if so where can I find the demonstration of my wrongness.
Shoog
