6V6 line preamp
Ok i changed multimeter non i have:
Anode 295v
On the grid stopper after Cin 88v
On cathode 120v
8v across 470r
Actually i'm listening good music with this parameters...
The resistors are from schema standard the supply is a CRCRCRC doubled in the last for the Teo channel
Here is your approximate loadline and operating point. Voltage over 470R should be like 11 V.
This value is odd though. Probably measuring fault. It should be the difference between voltage over 470R and cathode.
I guess it says that there is a small grid current, Otherwise there should be no drop over the 470 k.
It is true... I go to measure again...
Slightly leaky input cap could also change the expected grid to ground voltage measurement.
Some update: Not time to built a decent box, but I listen it (in wood-wine box) for a long time, with russian 6v6 and rca in metal case (6v6y) the first was definetively better: wide and loud at least IMHO and in my temporary realisation, absolutely silent, take a permanent place in my system.
Noone maybe. Some superlocal fb w less amplification , lower thd and unfortunately some higher Z-out is worth a try. Z is ok as is
If you can live with the lower gain and higher Zout it may be worth a try if only to judge the sonic impact of the decoupling cap.
I usually prefer the sound without the decoupling caps especially in a (phono) preamp. But then it's best to design with that in mind from the onset.
Another workaround would be to replace the cathode resistor with an appropriate LED if you don't mind the sand.
Ciao, 😉
