Low cost ES9018 DAC board GB
Thanks for the schematic, BoM and silkscreens. I was able to locate most of the datasheets, except the full datasheet of the ES9018K2M (which is probably available only under NDA).
Could you also send pdfs of the top and bottom layer tracks? I found what appears to be an error in the schematic on the left side of IC1, the ISO7230 I2S isolator, and the i2s connector. I'd like to see what's the best way to bypass or workaround that possible issue.
There is no error, already tested the board, probably you didn't clearly understood the schematic, ...
INA and INC (pins 3 and 5) of IC1 ISO7230 are shown as shorted together on the schematic sent. I'm reasonably confident that that was not the intent, and that each of INA, INB and INC goes to 3 different signal pins on the i2s input connector.
Did you test the board with the i2s isolator installed, and i2s input to the isolator?
Let me know where you found the shot between 3 and 5
Wish List
1)Turbon - 1 PCB, 1 ES9018K2M + TPS regs + 1 Crystek 950 (all pre-soldered)
2)Fredlock -1 PCB, 1 ES9018K2M + TPS regs + 1 Crystek 950 (all pre-soldered)
1) syklab - 2 PCB, 2 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered) + Crystek 950+ 2 TPS regs- PAID
3) richard_pc - 1 PCB, 1 ES9018K2M + 1 Crystek 950 + TPS(ALL pre-soldered) - PAID
4) freeman - 1 PCB, 1 ES9018K2M, 1 Crystek 950, TPS regs (all pre-soldered) - PAID
5) danzup - 1 PCB, 1 ES9018K2M (un-soldered) - PAID
6) tvicol - 1 PCB, 1 ES9018K2M (un-soldered) - PAID
7) atupi - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered - PAID
8) rredline - 1 PCB, 1 ES9018K2M + XG1000 oscillator + TPS regs (all pre-soldered) - PAID
9)Turbon - 1 PCB, 1 ES9018K2M + TPS regs + 1 Crystek 950 (all pre-soldered) - PAID
10)eledanca - 1 PCB, 1 ES9018K2M (pre-soldered) - PAID
11)Ryssen - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
12)vuki - 1 PCB, 1 ES9018K2M + XG1000 oscillator + TPS regs (all pre-soldered) - PAID
13)number9 - 1 PCB, 1 ES9018K2M+ Crystek 950 oscillator + TPS regs (pre-soldered) - PAID
14)dady - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
15)linuxguru - 1 PCB, 1 ES9018K2M + oscillator (both pre-soldered) - PAID
16) TheCoolestOne - 3 PCB, 3 ES9018K2M + 3 XG1000 oscillator (both pre-soldered) - PAID
17) mrsavage - 2 PCB, 2 ES9018K2M (pre-soldered) - PAID
18) hdrew - 1 pcb + 1 ES9018K2M + TPS regs + Crystek 950 - PAID
19) Touister - 1 PCB, 1 ES9018K2M + XG1000 oscillator + TPS regs (all pre-soldered) - PAID
20) free2dev - 1 PCB, 1 ES9018K2M + 1 Set of TPS regs (pre-soldered) - PAID
21) rbalu72 - 1 pcb + 1 ES9018K2M + 1 Crystek 950 + 1 Set of TPS (all pre-soldered) - PAID
22) Spartacus - 1 pcb + 1 ES9018K2M + 1 XG1000 (all pre-soldered) - PAID
23) SDF - 1 pcb + 1 ES9018K2M + TPS regs + 1 XG1000 (all pre-soldered) - PAID
