1) syklab - 2 PCB, 2 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered) + Crystek 950+ 2 TPS regs- PAID
3) richard_pc - 1 PCB, 1 ES9018K2M + 1 Crystek 950 + TPS(ALL pre-soldered) - PAID
4) freeman - 1 PCB, 1 ES9018K2M, 1 Crystek 950, TPS regs (all pre-soldered) - PAID
5) danzup - 1 PCB, 1 ES9018K2M (un-soldered) - PAID
6) tvicol - 1 PCB, 1 ES9018K2M (un-soldered) - PAID
7) atupi - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered - PAID
8) rredline - 1 PCB, 1 ES9018K2M + XG1000 oscillator + TPS regs (all pre-soldered) - PAID
9)Turbon - 1 PCB, 1 ES9018K2M + TPS regs + 1 Crystek 950 (all pre-soldered) - PAID
10)eledanca - 1 PCB, 1 ES9018K2M (pre-soldered) - PAID
11)Ryssen - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
12)vuki - 1 PCB, 1 ES9018K2M + XG1000 oscillator + TPS regs (all pre-soldered) - PAID
13)number9 - 1 PCB, 1 ES9018K2M+ Crystek 950 oscillator + TPS regs (pre-soldered) - PAID
14)dady - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
15)linuxguru - 1 PCB, 1 ES9018K2M + oscillator (both pre-soldered) - PAID
16) TheCoolestOne - 3 PCB, 3 ES9018K2M + 3 XG1000 oscillator (both pre-soldered) - PAID
17) mrsavage - 2 PCB, 2 ES9018K2M (pre-soldered) - PAID
18) hdrew - 1 pcb + 1 ES9018K2M + TPS regs + Crystek 950 (all pre-soldered) - PAID
19) Touister - 1 PCB, 1 ES9018K2M + XG1000 oscillator + TPS regs (all pre-soldered) - PAID
20) free2dev - 1 PCB, 1 ES9018K2M + 1 Set of TPS regs (pre-soldered) - PAID
21) rbalu72 - 1 pcb + 1 ES9018K2M + 1 Crystek 950 + 1 Set of TPS (all pre-soldered) - PAID
22) Spartacus - 1 pcb + 1 ES9018K2M + 1 XG1000 (all pre-soldered) - PAID
23) SDF - 1 pcb + 1 ES9018K2M + TPS regs + 1 XG1000 (all pre-soldered) - PAID
I will post my version of an program / schematics and how to connect LCD, and some other enhancements like IR command , adding an encoder , power on/power off and so on after i will receive my board . Also i will use the power on to trigger 12V for my Shiga clone CD player - an relay to power on /power off with this DAC at the same command.
Or you can look at " Sabre Hifiduino ess arduino program " . Only some minor modification need it if you know Processing/Wiring language (aka arduino language) .
Maybe it will be better to open a git hub project?I will post my version of an program / schematics and how to connect LCD, and some other enhancements like IR command , adding an encoder , power on/power off and so on after i will receive my board . Also i will use the power on to trigger 12V for my Shiga clone CD player - an relay to power on /power off with this DAC at the same command.
I have an adaptation of hiduino code for arduino due + touch screen as well
Good idea.
Sounds good.
I am too interested in the Arduino control project.
I am also planning to create a player based on either Home - Volumio - Audiophile Music Player or RuneAudio - Embedded Hi-Fi music player on BeagleBone Black. It is currently only available from https://specialcomp.com/beaglebone (for $45 + $7 S/H to USA) but a newer version C board should be shipped on May 5 from other distributors as well (though $10 more expensive).
Does someone know the cheapest source of the Amanero board?
Let's try to keep this this thread clean for Syllabe to give him space to manage the GB, and make 2 additional threads:
- one for build related experiences/BOM tweaks and questions and
- other one for DAC different implementations and DAC chip control.
If the ES9018K2M registries are the same or close to 9018 it will be very easy to implement or/and adapt an already arduino controller.
as for using an ARM device as a source there are several solutions. ...
If I understood correctly, the ES9018K2M datasheet can be requested via a official seller:
Company Sales Offices
I contacted those companies in order to get the full doc of the ES9018K2M.
They are kind of curious . I do not know what could be the right answers:
Can you tell me more about your interest?
• For what application would you like to use the ES9018K2M?
• When should development start?
• When should a prototype be ready?
• When should the development be finalized?
• When should production start?
• What would be the targeted annual volume?
Your feedback on this would be much appreciated.
ES9018 datasheet FYI.
http://myl8test.files.wordpress.com/2013/05/download-es9018-datasheet-here.pdf
How about one for the ES9018K2M?
Thank you very much, but it's about es9018k2m which is a bit different than es9018s.
- Group Buys
- Low cost ES9018 DAC board GB
