My boards made it all the way to Australia 🙂
Cheers.
Cool!
Cheers.
Australia not Austria 🙂
I wanted to know the value of resistor to be used for R1,R2 and R5 for Calvin buffer. The schematic shows this to be 100,75 and 6.8 ohms respectively where as the silk screen on the PCB mentions it to be 50, 100 and 10 ohms. What should we use?
I think its all in the build guide with advises from Hesener.
Prereg Groupbuy
Keep in mind, that there is a Groupbuy for Prereg Boards for the Paradise currently running.
Just place name and amount of boards you need in the list under
https://docs.google.com/spreadsheets/d/1eA-F1Z3nZYQPkwdGa0nRqHP2hrClLh4kcjPRQnRiodE/edit?usp=sharing
Than i will contact you later on with the details. Price will probably be the same as last time depending on the number of participants.
Walter
Walter
Marra,
You are correct, it was mentioned in the document by Alfred. For some reason, I had a old document which did not have the same information and hence I asked. Thank you for pointing this out.
New Prereg GB round - Final Deadline!!!
Hi Guys,
as we now reached a critical mass for a new GB for the Prereg (thanks Peter for doing it again), there will be a final deadline, next Wednesday, 30th of April 2014 at 11:37pm CEST!
is now locked. If someone wants to make an order for the GB, please send me an PM or E-Mail with the respective number of PCBs you want.
Everyone who has is listed until then gets further information from me via PM.
Price will be the same as last time: 44€ per Stereoset (=2 PCBs) + Shipping/Packaging (within Germany for 1 set: 4€, for 2 sets 4.60€, worldwide depends on country).
Walter
Hi Guys,
Walter
Alfred,
Thanks for your work, the boards arrived today in perfect condition, beautiful work !!!!
Thanks again !!!
Manolo
Thanks again !!!
Manolo
BTW I have a technical question regarding the Calvn Boards, if they are mounted through the external riaa points how then do I connect an external riaa after installing the Calvin ??
Manolo
Manolo
Exactly the same way. Remember the architecture of this amplifier is a transconductance input stage, followed by current mirrors, and the current is then changed back into a voltage through the impedance of the RIAA network. It is simply parallel to the connector. So you can always remove the RIAA components on the main PCB, add your own network externally and the Calvin buffer at the same points, as mentioned in the build guide.
hope that helps ! Glad to hear the boards arrived in Chile....
alfred
alfred
nr12,
Transistors arrived in New York last Saturday. Beautifully packaged. I really appreciate it for your hard work! Thank you very much.
nr12,
Hello Plasnu, was that a group buy for transistors, I assume they are correctly matched, who is selling them ??
Saludos,
Manuel
Saludos,
Manuel
Please check #1264 in this thread.
Thanks !!!! I had not seen that post !!! saved me a lot of work !!!
Please thank nr12, not me!
Yes, you can check documents a gazillion times and always find mistakes..... Please note that there was a bug in the BOM and regulator schematic - four of the resistors are now 120 Ohm, not 330 Ohm. I could change it in the BOM but unfortunately not in the schematic, will have to figure out a way to do this.
The PCB is alright, it has the correct text on the resistors, so if you just follow the PCB everything will be fine.
My apologies.....
alfred
My apologies.....
alfred
- Group Buys
- Paradise phono stage
