I m too not sure about my pass b1
I still have one problem with my b1
the sound is not dead center. Ive wasnt sure so made my GF hear it thru headphone and speaker system. The sound is more right focused. Everything sound slightly more from the right side! if I take out the B1 from the chain, the sound is back to dead center.
What can be the cause?
att pot? the pot is a TKD. the pot is fine im almost 100% certain.
Even before the problem with the pot, I had noticed the gain difference between channel but I thought that was cause by the other problems I had...
I did multiple test with just music and swapping the source. the left side always play slightly louder!
What can cause this?
By the sounds of it, you may be buying another pot. If that ends up being the case, you might consider taking a look at these and adding a remote control while you're at it:
BentAudio.com :: Alps
BentAudio.com :: Stepped
The stepped attenuator will give better channel to channel tracking.
I agree with Zen, short the wipers or use a "y" cable at the input making a mono signal to test.
Good luck!
Steve
