Funniest snake oil theories
Don't Criticise What You Don't Understand....
Audio Quest says all audio cables are directional and you have to listen them to determine which is the best way to use them. Sigh. They did not used to be that bad.
In the application of DA convertor stage, I have found 10mm wires to be directional.
The point is that L & R need to be in the same direction.
Swap the direction of L or R connection, and the centre image and focus can move sideways, and balance control does not fix it.
Try it.
Dan.
Too late, the snake oil guys got there first.
PS AUDIO PERFECTWAVE AC-10 at Music Direct
All conductors in the PerfectWave AC Series are spool tested at the factory for directionality and then wound into the power cables in the same direction. This attention to detail provides a remarkable coherence and special accuracy to the sound of connected equipment powered by a PerfectWave AC cable.
"Here's your sign."
Dammit! My million dollar idea!
I'll take it a step further then - get myself an electrician's license so I can go to audiophile homes and rewire their entire homes with properly oriented AC wire.
Or even make my own power company, with audiophile-quality hydroelectric dams. Because hydroelectric has better musical flow than coal fire.
Try it.
Dan.
I truly believe you are fooling yourself. Please go look at the definition of AC. Physics, not just a good idea, it's the law.
I wonder how many meters of cabl/wire the signals traveled through from instrument /mic, amplifier, mixer, etc to storage, then from storage media through post recording processing then on to storage again and finally from storage to distribution media?
As well it should,Modification then: Tar and feathers for charletons, and a nice Swedish sauna for those who buy charletons, help leach the chemicals out that made them into idiots who buy from them (-:
Much better.😀
Seriously I always wonder if the people who 'invent' market and sell this stuff are mad, evil or just deluded, don't know if I should hate or pity them. They sound so helpful....... they know I want to believe.😕
