As well it should,Modification then: Tar and feathers for charletons, and a nice Swedish sauna for those who buy charletons, help leach the chemicals out that made them into idiots who buy from them (-:Now that does sound medieval.
[wiki=]%[/wiki]
Don't Criticise What You Don't Understand....
The point is that L & R need to be in the same direction.
Swap the direction of L or R connection, and the centre image and focus can move sideways, and balance control does not fix it.
Try it.
Dan.
In the application of DA convertor stage, I have found 10mm wires to be directional.Audio Quest says all audio cables are directional and you have to listen them to determine which is the best way to use them. Sigh. They did not used to be that bad.
Try it.
Dan.
AC theory...understood.
Soldering...perfect.
Swapping direction of interconnects...no brainer.
Dan.
Dan.
I wouldn't be so harsh, but yeah, that's the general idea.
Surely power cables must be directional as well then. Of course desoldering/decrimping AC plugs is a bit of a hassle for an ABX test.... Clearly that means there is a market for direction-swappable power cords that's just waiting to be filled!?
Too late, the snake oil guys got there first.
PS AUDIO PERFECTWAVE AC-10 at Music Direct
"Here's your sign."
All conductors in the PerfectWave AC Series are spool tested at the factory for directionality and then wound into the power cables in the same direction. This attention to detail provides a remarkable coherence and special accuracy to the sound of connected equipment powered by a PerfectWave AC cable.
"Here's your sign."
Dammit! My million dollar idea!
I'll take it a step further then - get myself an electrician's license so I can go to audiophile homes and rewire their entire homes with properly oriented AC wire.
Or even make my own power company, with audiophile-quality hydroelectric dams. Because hydroelectric has better musical flow than coal fire.
Try it.
Dan.
I truly believe you are fooling yourself. Please go look at the definition of AC. Physics, not just a good idea, it's the law.
why don't you get an engineer's license and rewire the whole town, "directionally" ??
Because with this understanding of pgysics, he could not pass the state boards.
What if I buy a set of audio cables that are bundled together (L & R) , and the wires in them are oriented in opposite directions?
"Here's your sign."
I wonder if they use the same "E-meter" to check for directionality as a certain someone else?
se
I mean surely, it creates the tides, so it's a big deal! Imagine what it does to your electrons.
`my favourite amplifier has over 3000 metres of "signal" wire between input, interstage and output transformers ....... why should we worry about the humble metre of interconnect and its humble crystalline polarities ?? 🙂No doubt the motion of the earth relative to the aether has an effect on cables.
I wonder how many meters of cabl/wire the signals traveled through from instrument /mic, amplifier, mixer, etc to storage, then from storage media through post recording processing then on to storage again and finally from storage to distribution media?
Much better.😀As well it should,Modification then: Tar and feathers for charletons, and a nice Swedish sauna for those who buy charletons, help leach the chemicals out that made them into idiots who buy from them (-:
Seriously I always wonder if the people who 'invent' market and sell this stuff are mad, evil or just deluded, don't know if I should hate or pity them. They sound so helpful....... they know I want to believe.😕
exactly, where is demand, soon there will be supply (ka-ching)🙂Are you kidding?? It's purpose is not in audio. It's purpose is to make money! 😉
Jan
- Member Areas
- The Lounge
- Funniest snake oil theories
