Sound of various Pass amps
Sound of various Pass designs
Nelson,
It would be interesting to know your thoughts on how the Sony VFET amps sounded vs the Pass SIT amp vs the current (and maybe past) Pass 240 based products, the F series and maybe even the Aleph sound.
Perhaps a short description of each and what that design did really well and perhaps what it could have done better. Also perhaps how it performed into low impedance loads.
I realize how each sounds is subjective and all have sounded good. However, since you're likely one of very few people who have heard each topology, your perspective on each would be great info to know. I also think it could be useful for folks buying Pass equipment (new or used) who are wondering how a particular piece might fit into their system. Finally, it would also help those interested in DIY who may be trying to determine what to build. Essentially, it could serve as a guide that would evolve over time and could even perhaps be a sticky.
I realize you have a long list of to-do's, but given the number of designs over the last five years or so, I think it would be very useful. As this site has grown, it's become very challenging to wade through thousands of posts on each design to try to determine how each compares to others.
Thanks,
Steve
Reactions: Freedom666
You may not be able to name a favorite child, but a parent always has an
opinion about the characteristics.
I always keep in mind that someone else's experience will not duplicate mine.
Speaking strictly of the the FW amplifiers, my listening is generally restricted
to 90+ dB sensitivity and no tough loads, as the amps are low power and
typically low damping factor.
F5: Dynamic, accurate, a little unforgiving. On speakers with peaks in the
top end, it will reveal as too bright and annoying. On speakers with a slightly
diminished top end, it adds a little sparkle, this in spite of being flat out at
high as 500 KHz. Good control - if your speaker is a little boomy, it will tend
to tighten it up. Overall, probably the most neutral of the FW amps. It will
drive 4 ohm loads without particular issues. Oh, and it does sound very good.
J2: A more relaxed version of the F5. Decent bottom end control, a warm
midrange, excellent depth. Overall, one of the most popular pieces. Still
in production, it best hits the mainstream taste of the FW audience, probably
because it delivers a consistently pleasant sound. Not intended for 4 ohms
unless the speaker is particularly efficient, which is rare.
F3: An even more relaxed version of the J2. Not much power or control. Popular
with Avant Gardes and other horn drivers, and does smooth out the peaks in
the tops of a lot of full range drivers. Used to be my favorite for the
Feastrex and Lowthers over the F5, now has to compete with SIT-1 and
SIT-2 for that spot.
M2: Some people just like the sound of push-pull output stages, transformers
and no feedback, and this is what the M2 delivers. Limited bandwidth and
control, but a pleasant sound, and it will drive 4 ohms. Has a bit more noise
than the other amps due to hum pickup on the input transformers, although
nobody seems to mind very much.
SIT-1: Broke the mold in the ability to play with the load line of a no-feedback
Common Source amplifier that still has any damping factor. A very unique
harmonic signature that can be dialed in to taste - Lots or little of 2nd
harmonic of either phase. Literally the sound of one transistor clapping -
without the input buffer (which no one seems to use) there is only 1
transistor in the amp. Has tremendous clarity and depth, depending on
setting, spectral consistency with warmth and detail. It allows you to focus
on a single instrument in an ensemble, almost to the exclusion of all else if
you want. This is the amp that convinced me that absolute phase is not
such a subtle factor.
SIT-2: A SIT-1 with a constant current source load instead of a stack of
power resistors. More efficient but similar to the SIT-1, it is set at a single
load line setting, so is not quite as flexible or fun.
Sony SIT amp (the big one shown at CES): This is a push pull VFET follower
output stage. Dynamic, high power, good control, drives the crap out of 4
ohms. It was voiced around AR-1's, and shows them to good advantage. It
is primarily 3rd harmonic in character, so the aspect is a little different than
the single ended SIT designs, but it is very impressive, detailed and easy to
listen to.
You realize that the original VFET (SIT) designs from the 70's were not
Class A and had more complex gain paths. I speculate that things might have
turned out a little different if they had gone for simple Class A designs that
play more to the strength of these parts.
Of course tastes have changed over time.
listen to.
Nelson, thank you for your very interesting discription.
But how about your FW designs compared to actual PL XA.5/XA.8/Xs-amps?
Yes, PL-amps can handle heavier loads - but can you give us an impression how they sound with similar loads?
Reactions: wirewiggler
Make a house party use First Watt amplifiers is garantie of everybody dancing on the floor and beauty chicks become very relaxed 🙂
horns <100dB efficiency for pop up the volume and we go wonder
A Big Two Thumbs Up...
Nelson,
Excellent!
THANK YOU, THANK YOU, THANK YOU!
This will be a great reference.
(I think you pushed a few of soundhappy's buttons. Obviously I need to spend time in France...). 😱 :magnify:
Steve
It is amazing how many flares of outstanding there is. Each one of those amps are simply rare and unbelievable with the sound they produce. It is really important knowing speakers to make the right choice. I have built F5, F2, F3 and FJ2 in addition to Aleph 2, Aleph 30, and X600. My favorite is FJ2 and that is what I am listening with the utmost pleasure. The closest comparison is to the best SE tube amp minus disadvantages that tubes have. This amp has solid bass, very lovable mids and the best and most natural top I ever heard in an amp. On the brightness level, F3 is softest, followed by FJ2 with F5 leading. Yet, with not as bright speakers, F5 would be what doctor prescribed. It is pleasantly analytical and extended and it is very interesting comparing it with FJ2. That is maybe the best example that there is no universal best amp, just best amp for the job. I have not have opportunity to build or to do much of listening of SIT amps, but they suppose to be the next advancement to FJ2, which is really hard to believe to be possible. Nelson for Nobel, I tell ya... Hold on, add Zen Mod to it too. 🙂
Mr. Pass, I would like to thank you for sharing your ideas with the community.
I recently realized that some of the equipment I've worked on, some of the equipment I personally own, and some of the circuits I have emulated in my own designs are your circuits. I personally like the Stasis topography; it works very well with "difficult" loads. I think that is because the feedback is not taken from the speaker output, so the input stage is buffered from speaker back emf (and thus it not amplified). Please correct me if I'm wrong.
I haven't looked in this forum that much, but I will check it our from now on.
.....My favorite is FJ2 and that is what I am listening with the utmost pleasure.....
to be frank , my AR2 was first impressed with Mili BJ2 (not Mini) :rofl: , later advancing to sort of Turbo BJ2
Turbo - as typical scavenger , he had 2x24Vac xformers , not 2x18Vac , as prescribed .......... he had no space enough in case for proper stereo amp , so he just use two cases , as monoblocks
:devilr:
Aleph models
Found this post from 2003 describing the various Aleph models and thought I'd add it to this thread.
I have often said that the Aleph 2 was generally my favorite in
terms of aesthetics, power, and tonal balance. Aleph 3's are
cute as bugs, but don't have the power or control and lean a
little toward the mid/hi. The Aleph 1.2 had the best bottom end,
but was heading off toward a little less detail on the top than
the smaller models.
The Aleph 0 was a 3 gain stage piece. It measured better in
every respect, and could drive any impedance, in fact it had
almost exactly the same distortion vs power curve into 2 ohms
as it did into 8 ohms, which made it quite unique. It did,
however, sound more like a lot of the other high quality solid
state amps, a little less romantic by comparison.
Reactions: tonyEE and ElliJ
Power Mosfet Choices
While slightly off topic, I found this post from 2003 describing the sound of various output devices and thought I'd add it to this thread as well:
I received the following email question, which I think makes for worthwhile discussion:
(Quote) I have posted several questions on diyaudio Aleph-X thread concerning the more esoteric issues in selecting a mosfet for this amp. It had occurred to me that Nelson may be uncomfortable giving an outright answer on the optimum rail voltage and current bias in an open forum so I have decided to ask this privately. When I look at the transconductance figures of the IRF family when compared to their input capacitance, the IRFP240 looks like a relatively poor choice. As per Nelsons suggestions, I read the Zen v5 article and payed particular attention to the fig. 5-7 distortion graphs. The IRFP240 is a 200V part and so it is logical to me that it would provide much lower distortion figures as you increase the voltage rails but would there be commensurate effect with the other IRFP mosfets? To me, the IRFP044N, IRFP150N and IRFP150V have huge a huge transconductance to Ciss ratio compared to the IRFP240 and were designed for a lower voltage application so I would like Nelson (or any of his highly competent engineers) to just give it to me straight. What combination of rails and bias make the best sounding Aleph-X for each of the following parts?
IRFP044N
IRFP150V
IRFP150N
IRFP044
IRFP150 (end quote)
For the record, I experience no discomfort. It is true that I tend to pick IRF244's, partly because I own a zillion of them, having cornered the market on TO-3's. Of course the reason I did that was that I like the 244's sound in general.
Each of these Mosfets brings something different to the table, and each results in a different sound. Some people like the lower transconductance models, such as the early Mosfet like Hitachi's, and some like it higher. A lot higher.
It is my experience that picking the optimal part (or parallel group of parts) is an exercise in experiment and experience, and it is my opinion that for a given amplifier design there is an optimal characteristic for the transconductance.
I recommend the 044 for Zens because they benefit from maximal transconductance, which you get with the lower voltage types. For a Zen amp, high transconductance is a good thing, however it is traded off against Gate capacitance, which is not.
IRFP150's are nice parts. They look to me like two IRFP140's in parallel (the same applies to 250/240 comparison). The advantage in that case to the 140 is that two of them have greater dissipation capability, being in two packages.
According to my book, the 150 has about 1.5 times the Ciss of the 140, but also about 1.5 times more transconductance (this at 10 amps).
Just about any decent Mosfet will work in any of the Zens, X's, and XA's. Besides reliability, it's a question of sonic character.
As the aggregate transconductance gets higher in simple amps, the bottom end becomes more pronounced and you do get better control, but it seems that you are trading off against sparkle on the top, and vice versa.
You will also experience differences in the sound between Mosfets of the same type - remember that the published curves are typical examples. If you really want to nail the thing down, you have to substitute parts in and out and evaluate each.
So we pick a middle ground (or not), and try to enjoy what we've got.
Is this a good argument for bi/tri/quad amping? Yes, I think it is, as you can tailor the amps for best performance in a given spectral area.
It is also a fine example of something a DIYer can do that a manufacturer will never do? I think so.
