Pictures of your Tubelab amp
I just was not happy with the first chassis for this amp, it did not do it justice.
Here's mine with Trooper's first chassis!! I like Troopers first chassis very much.
Thank you, its a sheet of 4mm thick ally folded at the front and back.
Underneath is partitioned by ally angle and long thin sheets to give some resistance to sagging.
Most of the strength comes from the wooden sides which bolt to the main ally folded plate.
KT150s? How do you like them?
KT150s yes I like the sound VERY much, I was just going to take a listen to them for a few days and they've been in ever since I bought them, month and half or so.... I'm going to build another with those output tubes in mind, beef things up some more add more voltage and no electrolytics in the power supply. They replaced GL KT88s and sound better to my ears with VERY efficient horn loaded speakers with BIG 15" woofers...
Bob
First Time Tube Amp Build
This is the first amp I have built. Still needs to have motor run cap added, knob and power switch added. Sounded great but I may have a bad tube. Kinda bummed but should have replacements next week.
I'm not sure... I'll give it a try
no doesn't work for me either...
OK this is better.... see the attached sceen shot. I chose the forum type for copying the url.
NNote that you should resize the images before uploading to a picture sharing site. Better is to attach them to the post. This can be done by going into the advanced editor.
Tony.
