The OP said the zener was bypassed with a big cap. Such an arrangement is in fact extremely quiet.Post 10 has the right idea. This is for a headphone amp so low noise should be a priority, in which case you should definitely scrap the noisy Zener. IMO
bypassing a Zener with a big cap is very inefficent use of parts - the Zener's low dynamic Z with adequate bias makes for a high corner frequency - much better to make a RC low pass afer the Zener
Update: i (kind of) followed Mooly's circuit and it works.
This is my current schematic.
Mooly's schematic shows a 2nd capacitor where the question marks are. Minor question and pretty sure the answer is yes, but in case i missed something, can i put 100uF cap there? I happen to have one lying around. I don't know, shorting that TIP122 and now using a sensitive MOSFET made me paranoid about transients.
You don't normally put a capacitor in that position, since it will cause you to lose all the AC regulation that a regulator is supposed to provide! I'm not sure if it is a mistake in Mooly's diagram, or if he really means to regulate only DC and not AC (ripple).
Mooly?
Mooly?
It wasn't a fully worked example tbh, a workable circuit yes, but not optimised.
Here is the sim file (so you can alter and see the effect of changes). As it stands there is a pulsed load (severe test) and you can see the effect of making R6 either 15k or short and how the ripple alters. Its far less in amplitude with a cap fitted in that location. As always though, you need to balance all aspects of a design to best suit your needs.
That's because the capacitor makes the circuit work as a capacitor multiplier, not a regulator! For a regulator you would normally have a capacitor in parallel with R3 (1 to 10uF say), which increases the feedback as far as AC is concerned, and tends to stabilise the regulator.Its far less in amplitude with a cap fitted in that location.
That's why I said you need to balance all the design aspects 🙂
Do you want max ripple rejection or best performance against transient load fluctuations. There is no one size fits all.
If the load is dynamic (and a headphone amp whether class a or class b) should in practice have minimal changes in supply current) then you need to look at what the min and max variation might be and over what time period.
I posted the sim file so that it can be tweaked by the user to suit the requirements.
- Power Supplies
- Zener Follower - what did i do wrong?
