IRS2092 own design
Hi.
Can anybody tell me whether it will work?
Better now , but could be better if you move the coil and out cap to the place of electrolitics decouplers and place them nearer the MOSFETS.Try to make vs conection thicker .Keep in mind you have to place 0.1uF as close the MOSFETS you can.Place all the circuitry from pin 1 to 6 nearer 2092 to avoid pick emi .
Done, amp was playing, but when I had disconnected speaker, everything on PCB was hot and in a moment IRS and fet-s burned.
Unfortunately there wasn't C8A and heatsink, I have connected additional parallel resistors to R117A, R118A, R17A, because amp was clipping, when power supply was circa 2x35V, is possible that leads of that resistors was to long?
(img from IRAUDAMP7D: 500Wx1@ 8? / 250Wx2@ 4?, ±45 ~ 60V | DigiKey )
I have seen the output sit at +17VDC if there is no speaker connected.
And sometimes it runs OK.
I sold an amplifier and the buyer had tested the output before connecting a speaker and complained about the output sitting at 17VDC. He was worried it would damage his speaker. I had to tell him that the output can do strange things if no speaker is connected.
