Yes , it's sure to have some resistor load to have the DC feedback closed and stable . This is true not only for D class amps........A fixed resistor loading the amp?
To avoid unstable behavior near res. frequency of the output filter , a zobel network is required .
Leads of resistors truncated, 2k2 resistor on output like earlier, new IRF640N, IRS2092, about 450kHz switching frequency, rest almost same as iraudamp7d, added small heatsink, quiescent current at 36V --> 50mA, circuit don't heats too much.
Now with load or no load square waveform before output filter looks exactly the same.
I have connected it to 2x80V SMPS after changing some resistors and dead time to maximum, because quiescent current was more than 200mA! (Now I can't read value on 600mA ammeter, is to small.)
Amp is working, but small inductor heats a bit, maybe 50-60°C, but I think that it shouldn't be dangerous.
Is worth to buy better fets and bigger core for inductor? Arnold Sendust (like now) is good for such applications?
How much was supply voltage in Your amp?
+/- 65 volts
I see that T106-2 has AL=13.5, how much turns makes this inductance (27uH)?
I used about 20 turns.
I usually just wind it on till I cant get any more on of 18swg enamelled copper wire.
You can test it using a sig gen and scope by making a res circuit wit ha resistor and capacitor. Look for the short circuit across the LC at the res frequency.
Then use:
1
L=----------------------------------------
4 pi pi F F C
- Class D
- IRS2092 own design
